Старый 11.08.2006, 20:01   #1
tangolp is offline
tangolp
SQL store procedure
I was able to connect to an external SQL server database using the Axapta COM. Next, I'd like to execute a store procedure which requires me passing a parameter and the store procedure has an OUTPUT parameter. Can someone show me how to do this? Sample of I was able to connect to an external SQL server database using the Axapta COM. Next, I'd like to execute a store procedure which requires me passing a parameter from the client. Can someone show me how to do this? Sample of code would be very helpful. Thanks!
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX: SQL Sever 2008 - Performance with Dynamics AX 2009 - Resource Governor Blog bot DAX Blogs 0 23.01.2009 22:05
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
aEremenko: Диагностика проблем при установке Microsoft Dynamics Ax 4.0 на Microsoft SQL Server 2005 Blog bot DAX Blogs 0 28.10.2006 16:01
Часовой пояс GMT +3, время: 04:27.
