Старый 28.10.2006, 16:40   #1
Fred Shen: Cache size for recId allocation
Источник: http://fredshen.spaces.live.com/Blog...E4E3!181.entry
In Dynamics AX, recId is assigned according to the nextVal (ID -1, name SEQNO) of SystemSequence table. But the next value of RecId is not always retrieved from the table, and it is cached in client machine's memory. In AX3.0, the default cache size is 25.
Developers can change the default cache size using SystemSequence class:
In the startupPost method of Application class, you can add the following code:
    SystemSequence SystemSequence;
    SystemSequence = new SystemSequence();
    SystemSequence.setCacheSize(30);
As a result, recIDs are drawn in sets of 30. That also means that the next value of SystemSequence table will be increased by 30 each time.
In AX 4.0, recIds will be generated unique per table instead of per company.
So for each table, there will be a nextVal (ID -1, name SEQNO) in SystemSequence table. The cache size for recId allocation is increased to 250. And AX 4 does not allow changing cache size for recId allocation anymore.
Fred Shen: Create a new method in runtime Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Read and alter registry settings in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Tips on optimizing primary index in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 10:15.
