Старый 28.10.2006, 16:40   #1
Fred Shen: Date data type in Query Range Value Expression
Источник: http://fredshen.spaces.live.com/Blog...E4E3!177.entry
Query range value expressions can be used in any query, where you need to express a range that is more complex than that made possible with the usual dot-dot notation.
Especially to use Or clause in query, you definitely need to use Query Range Value Expression.
Today I just want to investigate more about the date data type in Query Range Value Expression.
To retrieve records where the transaction date is before 21st June, 2006. You can use Date2StrXpp() to format the date:
axaptapedia: Packing date range values in queries Blog bot DAX Blogs 1 09.11.2007 13:10
axaptafreak: Label for Query Range cannot be modified (still) Blog bot DAX Blogs 2 25.07.2007 10:09
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Pass complex data types to 3rd party DLLs in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 05:35.
