Старый 28.10.2006, 16:40   #1
Fred Shen: Dialog screen events
Источник: http://fredshen.spaces.live.com/Blog...E4E3!160.entry
Some body may wonder if it is possible to use control's event methods in dialog just like what we do in the form. For instance, the change of a given dialog control's value will result in changes in other control's value.
In Axapta, if you use a class that extends RunBase, it allows you to implement the screen events in dialog.
1. in dialog method
    protected Object dialog(…)
         dialog.allowUpdateOnSelectCtrl(true);
Then, when a control is selected, the runbase.dialogSelectCtrl() method is called.
2. in dialogSelectCtrl method
    public void dialogSelectCtrl()
        super();
        //processing here
DynamicsTech: How to modify the behavior of dialog boxes to enable forms to appear in full-screen mode in Microsoft Dynamics AX Blog bot DAX Blogs 0 13.04.2007 12:10
Fred Shen: Failed to create COM objects on AX 4 AOS Blog bot DAX Blogs 0 08.12.2006 19:14
Fred Shen: Change the combobox options in RunbaseBatch class Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 02:26.
