Старый 12.04.2007, 16:10   #1
Dave: XML File Size limitation using FindList AIF Actions
Источник: http://daxdave.blogspot.com/2007/03/...-findlist.html
If you develop a findList Action in AX AIF and your dataset is going to be bigger than about 3MB, you will need to follow some steps within the AX 4.0 release notes. Search through it and find and execute the steps to add/modify the 'maxbuffersize' registry key.
Dave: AIF Configuration and Additional Findings Blog bot DAX Blogs 1 04.11.2009 17:29
axStart: InfoPath with default AIF file inbound offline Blog bot DAX Blogs 0 20.05.2008 19:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Dave: Followup to AIF Configuration Entry Blog bot DAX Blogs 0 28.10.2006 19:01
Часовой пояс GMT +3, время: 19:04.
