Старый 16.07.2007, 02:58   #1
dynamicsmatters: Refreshing screen info in V4
Источник: http://dynamicsmatters.blogspot.com/...nfo-in-v4.html
I have come accross a small change in behaviour from V3 to V4 which could potentially be rather adverse in its effects.
In V3 if you want to update a screen f.ex. and refresh it in a uniform manner then you called
element.lock()
did all your manipulation of screen elements
called redraw or refresh (if you needed to re-read the data)
and
called element.unlock()
The functions are still there but they currently seem to do nothing, I suspect it is related to MS teams taking over some of the screen painting functionality and they are probably using some other MSFT code package to update screen information. But this leaves me pretty much in limbo as I have to get the user to activate the scroll bar to change the screen elements as redraw seems to have been de-activated as well.
Anyone else noticed the above and more to the point has anyone found a workaround to this annoying little bug ?
I will share here if I find one, my google help as not worked :-), I have not seen it commented publicly anywhere yet.
Take Care
Sven
dynamicsmatters: Refreshing Screen Info in V4 PII Blog bot DAX Blogs 0 20.07.2007 18:00
dynamicsmatters: V3 - V4 Interesting bug Blog bot DAX Blogs 0 16.07.2007 02:58
Вылетает аxапта 4.0 при завершении работы Delfins DAX: Прочие вопросы 5 27.06.2007 15:43
dynamicsmatters: Upgrading from V3 to V4 P1 Blog bot DAX Blogs 2 14.03.2007 22:00
dynamicsmatters: V4 Second look Blog bot DAX Blogs 0 21.01.2007 17:24
Часовой пояс GMT +3, время: 05:14.
