Старый 04.08.2007, 19:50   #1
Arijit Basu: Creating Sales Orders via X++
Источник: http://daxguy.blogspot.com/2007/08/c...ers-via-x.html
For beginner AX developers, I’m listing some codes which will help someone to create Sales Orders (Similar can be applied to PO) via X++ codes. This may be helpful to new Developers. [Level 200]
Some important Objects which are to be referred and understood are:
-Tables\SalesTable
-Tables\SalesLine
-Tables\InventDim
-Tables\CustTable
-Tables\InventTable
-Classes\SalesTableType {The InventType Hierarchy}
Sample Code [Very basic]
static void SalesOrderCreation(Args _args)
SalesTable salesTable;
NumberSeq NumberSeq;
SalesLine salesLine;
InventDim IDim;
ttsbegin;
NumberSeq = NumberSeq::newGetNumFromCode(SalesParameters::numRefSalesId).numberSequence);
//=======Table=======
salesTable.SalesId = NumberSeq.num();
salesTable.initValue();
salesTable.CustAccount = "4000"; //Enter Customer Acount
salesTable.initFromCustTable();
salesTable.InventLocationId = "GW";
salesTable.insert();
//========Line=======
salesLine.clear();
salesLine.SalesId = salesTable.SalesId;
salesLine.ItemId = "IS2082SAIL"; //Enter Item ID
IDim.InventColorId ="CU"; //Enter Item Dimensions
IDim.InventLocationId = "GW";
IDim = InventDim::findOrCreate(IDim);
salesLine.InventDimId = IDim.inventDimId;
salesLine.createLine(NoYes::Yes,
NoYes::Yes,
NoYes::Yes,
NoYes::Yes,
NoYes::Yes,
NoYes::Yes);
ttscommit;
Info(salesTable.SalesId);
The above code is very basic but will help you with the concepts and the same can be extended to create PO
Happy DAX-ing :)
Arijit Basu: Using AX .NET BC to create Purchase Orders Blog bot DAX Blogs 0 14.06.2008 14:10
Issues concerning X++: Entering sales orders over the phone... Blog bot DAX Blogs 0 10.11.2007 06:52
Arijit Basu: Updated documentation for Microsoft Dynamics Mobile Development Tools and Microsoft Dynamics AX Mobile Sales Blog bot DAX Blogs 0 07.09.2007 15:10
Часовой пояс GMT +3, время: 17:43.
