Старый 20.05.2008, 22:45   #1
Hub is offline
Hub
"An unexpected exception occurred" во время установки.
Сообщение: "An unexpected exception occurred. See ...\DynamicsSetupLog.txt" -- во время установки.
Windows XP, Axapta 4 sp1, SQL 2005 Dev. Edition.
Log file:
=== Setup logging started: 20.05.2008 22:09:57 ===
Running file: C:\DOCUME~1\Pasha\LOCALS~1\Temp\AxSetup.exe
Exe Version: 4.0.2214.0
Property: AosReportErrors set to: '0' (False)
=== Loading parameters from file ===
Property: RelatedFilesDir set to: 'E:\Distributives\Dynamics AX 4.0 SP1\'
=== Starting evaluation of existing installation state ===
Client.msi Installed: False
ApplicationIntegrationServer.msi Installed: False
NetBusinessConnector.msi Installed: False
ComBusinessConnector.msi Installed: False
=== Checking parameters ===
=== Starting UI phase ===
Property: LicenseTermsVersion set to: 'RU'
Property: RunMode set to: 'SingleComputer'
Property: InstallDatabase set to: '1' (Create)
Property: InstallApplication set to: '1' (Copy)
Setup has detected that you are installing Object server on an operating system that is not supported for Microsoft Dynamics AX. The supported operating system is Microsoft Windows Server 2003 with Service Pack 1.
Property: InstallAos set to: '1' (True)
Property: ClientAosServer set to: 'PASHAN1'
Property: InstallClientUI set to: '1' (True)
Property: InstallReportingServer set to: '0' (False)
Property: InstallApplicationIntegrationServer set to: '0' (False)
Property: InstallNetBusinessConnector set to: '1' (True)
Property: InstallComBusinessConnector set to: '0' (False)
Property: ClientLanguage set to: 'RU'
Property: ClientHelpLanguages set to: 'EN-US;RU'
Property: ApplicationRegion set to: '-'
Property: AosInstanceName set to: 'Company5'
Property: AosInstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\40\Server'
The localized name for the NT Authority\Network Service account has been identified as NT AUTHORITY\NETWORK SERVICE.
Property: AosAccount set to: ''
Property: AosAccountPassword set to: '**********'
Property: DbServerType set to: '0' (SqlServer)
Property: DbSqlServer set to: 'PASHAN'
System.Data.SqlClient.SqlException: A connection was successfully established with the server, but then an error occurred during the pre-login handshake. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 0 - No process is on the other end of the pipe.)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParserStateObject.ThrowExceptionAndWarning()
at System.Data.SqlClient.TdsParserStateObject.WriteSni()
at System.Data.SqlClient.TdsParserStateObject.WritePacket(Byte flushMode)
at System.Data.SqlClient.TdsParser.SendPreLoginHandshake(Byte[] instanceName, Boolean encrypt)
at System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, SqlConnection owningObject)
at System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject)
at System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart)
at System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
at System.Data.SqlClient.SqlConnection.Open()
at Microsoft.Dynamics.Setup.InstallSqlServer.Connect()
Property: DbSqlServer set to: '(local)'
Connected to SQL Server: (local)
Property: DbSqlDatabaseName set to: 'Dynamics5'
Property: ApplicationInstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\40\Application'
Property: InstallApplication set to: '2' (DeleteContentsThenCopy)
Property: ClientInstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\40\Client'
Property: AosStart set to: '1' (True)
=== Starting execution phase ===
=== Setting up Database server Dynamics5 ===
Completed setup of Database server Dynamics5.
=== Setting up File server ===
Completed setup of File server.
=== Setting up Object server ===
Exception = System.Management.ManagementException
Message = Not found
FullText = System.Management.ManagementException: Not found
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObject.Get()
at Microsoft.Dynamics.Setup.Misc.GetMachineDomain()
at Microsoft.Dynamics.Setup.InstallSqlServer.GrantAosAccessToRemoteSqlServer()
at Microsoft.Dynamics.Setup.MainForm.AosDbAccess()
at Microsoft.Dynamics.Setup.MainForm.s250Timer_Tick()
==== Setup ended before completion. ===
После ошибки установка исчезает. БД на сервере создается, но остается пустой.
Буду очень благодарен за помощь в решении проблемы, возникающей во время установки.
Старый 20.05.2008, 23:33   #2
Hub is offline
Hub
Проблема решилась: переменную среды не менял...
Старый 19.12.2009, 12:09   #3
AX-DMiTRy is offline
AX-DMiTRy
Как решилась то?
ax4.0
Закупка на проект "Время и расходы" Sentry DAX: Функционал 6 19.02.2016 14:09
RPC exception 5 occurred (AX2009) player DAX: Администрирование 6 30.05.2012 11:38
RPC error: Exception 3221225495 occurred in session 1 Ivanhoe DAX: Администрирование 7 03.03.2009 08:03
Время созданного "сейчас" файла меньше timenow на 4 часа Gustav DAX: Программирование 20 04.09.2006 18:59
Поле с типом "Время" Кирилл DAX: Программирование 9 06.05.2004 10:53
Часовой пояс GMT +3, время: 03:56.
