Старый 29.05.2008, 23:06   #1
25,644 / 848 (80) +++++++
Creating additional environment
Источник: http://alexvoy.blogspot.com/2008/05/...vironment.html
If you have chosen to create an additional environment by means of copy-paste and backup-restore commands do not forget about one little thing.
1. In MS SQL management utility do backup of the database of the environment that you have chosen as an 'original' one.
2. Create another database and restore your backup to it (restore transactions logs backup too if presented).
2.1. (A litle important thing!) In the database you should find SysServerSessions table and delete all rows there.
3. Copy-paste C:\Program Files\Microsoft Dynamics AX\Application\Appl\Standard or other folder where your original application was installed with other appropriate name. E.g.:
C:\Program Files\Microsoft Dynamics AX\Application\Appl\Standard_Test
4. From DAX Setup install additional Object Server having pointed this instance to the recently created database and unchecked Start the AOS Windows service as part of installation option.
5. With Microsoft Dynamics AX Server Configuration Utility choose the new instance of AOS, create a new configuration based on the active configuration and set Application instance to the new one.
Dave: AIF Configuration and Additional Findings Blog bot DAX Blogs 1 04.11.2009 17:29
Creating Custom Dynamics AX Services Blog bot DAX Blogs 0 17.12.2008 12:05
Dave: Creating 'Permanent' Indexes on DataAreaId in Dynamics AX Blog bot DAX Blogs 0 29.02.2008 05:37
casperkamal: Creating graphs in Dynamics Ax Blog bot DAX Blogs 1 10.04.2007 21:39
casperkamal: Creating custom Picking list in Dynamics - Part II Blog bot DAX Blogs 0 22.03.2007 21:41
Часовой пояс GMT +3, время: 22:11.
