Старый 12.06.2008, 11:05   #1
Dynamics AX: Dynamics AX 2009 System Requirements
Источник: http://dynamics-ax.blogspot.com/2008...uirements.html
I wanted to take the time tonight to post a link to the Dynamics AX 2009, posted system requirements:
Posted System Requirements
I thought the following was interested, as I did not realize this:
"Software requirements for all computers
The following software must be present on a computer before any Microsoft Dynamics AX components can be installed:
• Microsoft .NET Framework 3.5"
So the 3.5 .Net Framework is being required, making the pass on 3.0 framework. This is actaully very interesting, and also great news, because this means you can take advantage of all the great things in the .Net 3.5 framework.
Update:
I also went back through, and read the System Requirements document in closer detail. In doing so, I came across this:
"Both the 32-bit and 64-bit versions of the .NET Business Connector are installed when you are using a 64-bit operating system."
So looking at this, means we now have a 64-bit version of the .Net business connector to use. This in turns mean greater access to larger memory chunks, and therefore a more stable, and more scalable .Net Business Connecter in Dynamics AX 2009. Very cool!
Check back soon!
"Visit the Dynamics AX Community Page today!"
Find a job at: DynamicsAXJobs.com, also post a job for only $99.00!
За это сообщение автора поблагодарили: aidsua (1).
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Dynamics AX: Business Intelligence in Dynamics AX 2009 (Part I) Blog bot DAX Blogs 0 26.06.2008 02:19
AX UK: System Requirements for Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 07.06.2008 00:05
Часовой пояс GMT +3, время: 06:48.
