Старый 16.06.2008, 15:27   #1
GM2005 is offline
GM2005
Вышел Microsoft Dynamics AX 4.0 Service Pack 2 Feature Pack 1 for Eastern Europe
Changes specific to the Russian functionality
Bug ID
Knowledge Base ID*
Description
26690
940701
Different sales tax amounts in a AR Free text invoice: in Totals inquiry and in a Sales tax form
27299
941759
Adding two lines in the Russian country-specific invoice format according to a local Russian legislative typical inter-industry reporting form 'TOPГ-12'
27636
942475
The system calculates incorrectly the amount in the line of FA Journal for "putting into operations" transaction for models of the account which currency is distinct from base currency.
27969
942431
Using the sales order function ’Update remaining delivery’ ends up with stack trace error
27971
942434
Stack trace error when printing Reimbursement slip/Receipt order from a Packing slip journal
28581
943098
RU- AC& AP\ Contracts\ Payment schedule is not filled in
28812
943572
Purchase book lines does not show adjusted tax amount
30144
944512
Stack trace error occurs when user is going to print Invoice For Payment from AC \ Stack trace error occurs when user is going to print Packing slip with Reimbursement order from AP
30722
945157
Dimensions in the transaction for write off cost item to FA (Db08 Cr 10) is picked up from fin dimensions from FA Posting model
30920
945237
Inventory Error message occurs when Transfer or Requirement slip is printing in case of Officials was tried to change by user
30926
945566
An error message "A section in the report is higher than the actual page size allows" in reports "Customer base data", "Vendor base data"
33240
947842
An error message “Voucher … is already used as of date …” arises when transforming a customer payment to prepayment
33963
948827
Half year straight line life remaining depreciations are not correct in Eastern Europe GLS
34734
950197
Error "Voucher XXX is already used as of date YYY" when two vendor transactions are settled together
34971
949836
RTax25Registers | Non warehoused goods register | Register calculation results do not include some transactions
36529
951572
Act of Adjustment reports shows incorrect zero debit sum in some scenario
37011
951525
Digits' delimiter in the update "Electronic reporting in txt format"
38176
953757
Company address in the Acceptance report (FA-1) if a company Address type is International
Старый 16.06.2008, 16:27   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
\Classes\ReleaseUpdateDB401_Cust\updateFacture_RU
trans.LineAmountMST   = round(custInvoiceTrans.LineAmountMST      * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff);
trans.TaxAmountMST    = round(custInvoiceTrans.TaxAmountMST       * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff);
trans.VATAmountMST    = round(custInvoiceTrans.VATAmountMST_RU    * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff);
trans.ExciseAmountMST = round(custInvoiceTrans.ExciseAmountMST_RU * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff);
Того, что существуют строки накладной с нулевой суммой, явно никто не ожидал
И еще лезут в голову всякие нехорошие слова при сравнении по слоям \Data Dictionary\Base Enums\RTax25TaxModule (имеется слой с российскими зарплатой и кадрами)
Зато сделали импорт курсов валют с сайта ЦБ
-ТСЯ или -ТЬСЯ ?
Старый 16.06.2008, 16:58   #3
Atar is offline
Atar
Консультант
287 / 101 (4) +++++
Обновленный меточный файл с полностью русскими метками есть там?
Старый 16.06.2008, 17:42   #4
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2156 (80) +++++++++
Много сделано по сторнированию операций, в том числе по складскому модулю. Надо изучать
Ivanhoe as is..
Старый 16.06.2008, 17:43   #5
Raven Melancholic is offline
Raven Melancholic
Аватар для Raven Melancholic
2,164 / 1296 (48) ++++++++
33240
947842
О, не прошло и каких-то пять лет с момента появления как исправили
Старый 16.06.2008, 18:29   #6
Alex05507 is offline
Alex05507
33 / 12 (1) ++
Сообщение от Atar Посмотреть сообщение
Есть там меточный файл, только вот совсем непонятно все или не все там переведено. Вроде как заявляется (что в принципе корретно) что исправляется то, что было зарегистировано ранее как непереведенное или неправильно переведенное, то есть то что не заявлено непереведено
Старый 17.06.2008, 20:51   #7
Сообщение от Vadik
Да уж... Причем в русских старых демоданных от 3.0, попрошу заметить (они у меня в 4.0 из 3.0 перекочевали стандартным апгрейдом в свое время).
А никому не приходится хранимые процедуры в MS SQL создавать при апгрейде, которые толи не создались, толи куда-то делись, но на их отсутствие пакетный сервер ругается? Или это только я такой несчастливый?
Документацию чтоли почитать ...
Старый 24.06.2008, 12:06   #8
Stainless is offline
Stainless
Columbus IT
34 / 114 (4) +++++
Можно скачать здесь:
https://mbs.microsoft.com/partnersou...E_Download.htm
Старый 12.07.2008, 11:17   #9
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,323 / 3547 (125) ++++++++++
Чего-то то ли я торможу - то ли не вышел los(lop)-слой с российскими зарплатами и кадрами, поднятый на этот GLP?
Ибо ощущение после "вливания" этого FP - (26 ошибок компиляции) говорят о том, что должны были поднимать... Нет?
Старый 15.07.2008, 09:51   #10
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
У нас стоит FP1 и общий, и FP1 RHRM - ошибок нет.
Ivanhoe as is..
Старый 15.07.2008, 10:17   #11
sukhanchik
Не... не втыкаю. Вот гляжу в партнерсорс...
Вижу: (Support-Service Packs) Ссылка на SP2FP1 - дата последнего изменения страницы 11.06.2008. Качаю - смотрю - GLP-слой. Дата его последнего изменения - 09.06.2008
Теперь рыщу в поисках HRM & Payroll для России.
Вроде нахожу: (Support-Product Releases) Ссылка на RHRM. Здесь дата последнего изменения страницы - 13.02.2008. Ладно - смотрю - на странице 3 ссылки - первая для 4.0SP1, вторая для 4.0SP2, третья просто сама по себе - ссылка на FP1 RHRM. Написано:
Feature Pack 1 for the Russian HRM and Payroll modules - Contains regulatory updats for Russian HRM and Payroll modules for Microsoft Dynamics AX 4.0 SP2 with Eastern Europe GLS. All functionality is in the LOS layer.
Т.е. тут человеческим языком сказано - что LOS-слой сделан для SP2 с GLS (а не GLP!) слоем.
Ладно - качаю FP1 RHRM - вынимаю LOS-слой. Вижу у него дата последнего изменения - 30.01.2008. Наложение слоя - ессно ведет к куче ошибок.
Может кто знает другую ссылку и я неверно нашел RHRM?
Последний раз редактировалось sukhanchik; 15.07.2008 в 10:20.
Старый 15.07.2008, 11:44   #12
Peter Savintsev is offline
Peter Savintsev
246 / 119 (4) +++++
Та же фигня. Правда, не 26, а 24 ошибки. Преимущественно в объектах с префикcами RTax и RAsset. Версия приложения 4.0.2501.347.
Старый 15.07.2008, 12:41   #13
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Беру свои слова обратно - при компиляции ошибки появились (проверил на RTax*).
Ждем нового релиза RHRM как после выхода DAX SP2?
ЗЫ: у меня приложение 4.0.2501.122, ставилось: SP2 EE, RHRM для SP2, FP1 RHRM, FP1 EE. Чего-то не хватает или порядок установки другой?
Ivanhoe as is..
Последний раз редактировалось Ivanhoe; 15.07.2008 в 12:47.
Старый 15.07.2008, 14:10   #14
Peter Savintsev
246 / 119 (4) +++++
Порядок установки не помню, т.к. накатывал FP1 на давно стоявшее тестовое приложение. Вроде такой, но не помню, устанавливал ли я FP1 RHRM. Есть какой-то способ проверить, что он установлен?
Что касается версии приложения, то она определяется методом \Classes\ApplicationVersion\applBuildNo. У меня этот метод на слое glp, т.е., по-видимому, этот билд определяет SP2 FP1 EE. Проверьте, на каком он слое у вас. Предполагаю, что на los/lop и там как раз указана версия 4.0.2501.122. Скорее всего, это версия FP1 RHRM.
Старый 15.07.2008, 14:19   #15
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Так и есть - метод на Los-слое.
Ну проверить FP1 RHRM можно, например по Штатному расписанию - если в Расчеты с персоналом / Кадровый учет / Состав / только одна форма "Штатное расписание" и нет "Хронологии расписания", то он стоит.
Ivanhoe as is..
Старый 15.07.2008, 14:38   #16
Peter Savintsev
246 / 119 (4) +++++
Судя по тому, что у меня и хронология и само штатное, FP1 RHRM у меня не установлен. Щас попробую накатить его, но вряд ли результат будет положительный...
Feature Pack 1 for Microsoft Dynamics AX 3.0 Service Pack 6 EE Poleax Microsoft и системы Microsoft Dynamics 3 24.02.2009 18:14
Российские пользователи опробуют новую версию Microsoft Dynamics AX до выхода системы на отечественный рынок belugin Microsoft и системы Microsoft Dynamics 2 02.11.2008 21:37
Вышел Microsoft Dynamics AX SP2 / SP2 EE George Nordic Microsoft и системы Microsoft Dynamics 24 21.09.2007 17:07
Microsoft Dynamics AX 4.0 Service Pack 1 release mazzy Microsoft и системы Microsoft Dynamics 0 15.03.2007 16:47
Convergence 2006 EMEA - Dynamics AX presentations belugin Microsoft и системы Microsoft Dynamics 1 14.11.2006 11:21
Часовой пояс GMT +3, время: 15:12.
