Старый 10.10.2008, 06:06   #1
Solutions Monkey: Ax Report Web Part properties
Источник: http://blogs.msdn.com/solutions/arch...roperties.aspx
Microsoft Dynamics AX report web parts are used in Role Centers and in Enterprise Portal pages. If you need to pass parameters to the report throug query string , you can do so in the URL with this syntax .Parameters.=
For example In the Ax report webpart , set the paramter selector value to Report1. And let us say the report has a paramter defined with the name CashInflowvsCashOutflow_EndDate. In that case the query string will be
http://axepdemo/sites/DynamicsAx/Ent...aspx?WCMP=CEU&Report1.Parameters.CashInflowvsCashOutflow_EndDate=10/01/2007
Solutions Monkey: KPIs in Role Center Business Overview Web Part keeps loading all the time and never ends. Blog bot DAX Blogs 0 12.03.2009 07:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Solutions Monkey: EP Web Part connection Blog bot DAX Blogs 0 28.10.2006 16:40
