Старый 11.11.2008, 08:05   #1
25,644 / 848 (80) +++++++
epblog: Sharing Code between User Controls in EP
Источник: http://blogs.msdn.com/epblog/archive...ols-in-ep.aspx
One of the commonly asked questions is - How do I share code between different EP controls. Enterprise Portal in AX 2009, supports sharing of code using a dummy User Control (we call this a dummy user control as it doesn’t have any UI and contains only...(read more)
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Dynamics AX: Microsoft Dynamics AX EP Team Blog - Filtering a DataSet from Code behind Blog bot DAX Blogs 0 04.12.2008 03:07
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 09:11.
