Старый 20.11.2008, 02:07   #1
25,644 / 848 (80) +++++++
MS Outlook and CRM Tasks Synchronization Issue
Источник: http://alexvoy.blogspot.com/2008/11/...crm-tasks.html
Recently I found out an issue with synchronization of tasks between CRM module and MS Outlook in AX4.0SP2.
It looks like MS Outlook does not understand the command and causes the following error:
Method 'sort' in COM object of class '_Items' returned error code 0x80020009 (DISP_E_EXCEPTION) which means: Propri?t? « Start » inconnue.
I changed the synchronizeTasksOutlookToAxapta method of SmmOutlookSync_Task class in order to fix the problem like it was done in AX2009:
taskItemsCollection.sort('[Start]', false);
to
#define.startDateProperty('StartDate')
// Turn sort and include recurrences ON to get recurring tasks
taskItemsCollection.sort(#startDateProperty, false);
!!!какие порты и протоколы использует MS CRM клиент для Outlook Venice Dynamics CRM: Администрирование 21 22.01.2010 10:44
Microsoft Dynamics CRM Team Blog: Drowning in Outlook Reminders? This might help. Blog bot Dynamics CRM: Blogs 0 18.02.2009 21:05
Ошибка при синхронизации записей Outlook MS CRM 3.0 Bondonello Dynamics CRM: Администрирование 8 23.09.2008 11:38
Microsoft Dynamics CRM Team Blog: CRM4 Outlook Client – Issues and Fixes Blog bot Dynamics CRM: Blogs 0 07.08.2008 01:05
Ошибка при установке MS CRM Outlook клиента flay Dynamics CRM: Администрирование 0 29.06.2006 10:16
Часовой пояс GMT +3, время: 10:30.
