Старый 25.03.2009, 16:33   #1
petr is offline
petr
561 / 201 (8) ++++++
Баг при печати налогового кода
DAX 5.0 SP1
Класс TaxJournalSpec метод taxSpec()
Исходный код (уже исправленный, баги выделены комментариями)
 boolean taxSpec()
    TaxWriteSelection   taxWriteSelection;
    TaxGroup            lastTaxGroup;
    InventTransId       lastInventTransId;
    LedgerAccount       lastOperationAccount;
    Set                 taxSpecCodeSet;
    if (released  == NoYes::No)
        // BP Deviation Documented
        taxSpecTmp.setTmp();
        lastTaxGroup        = '';
        lastInventTransId   = '';
        lastOperationAccount = '';
        taxSpecCodeSet = this.initTaxSpecCodeSet();
                if (!taxJournalTrans.ExemptCode && taxJournalTrans.TaxPrintDetail != TaxPrintDetail::TaxGroup)
                    taxWriteSelection = TaxTable::find(taxJournalTrans.TaxCode).TaxWriteSelection;
                    if (taxWriteSelection == TaxWriteSelection::PrintCode)
                        if(taxJournalTrans.PrintCode)
                            taxSpecTmp.PrintCode    = taxJournalTrans.PrintCode;
                        else
                            taxSpecTmp.PrintCode    = TaxTable::printCode(taxJournalTrans.TaxCode);
                    if (taxWriteSelection == TaxWriteSelection::TaxRate & /* баг - & вместо &&*/  taxJournalTrans.TaxValue)
                        taxSpecTmp.PrintCode    = strfmt("%1",taxJournalTrans.TaxValue);
        select
            sum(TaxBaseQty),
            sum(SourceTaxAmountCur),
            sum(SourceBaseAmountCur),
            sum(SourceRegulateAmountCur),
            sum(TaxAmount),
            sum(TaxBaseAmount)
        from taxSpecTmp
          group by TaxSpecCode, TaxDirection, ExemptTax, ExemptCode, SourceCurrencyCode, TaxAutoGenerated, TransDate, euroTriangulation /* баг - забыли PrintCode */
          where taxSpecTmp.TransTableId == sourceTableId    &&
              taxSpecTmp.TransRecId   == sourceRecId;
    else
        next taxSpecTmp;
    released  = NoYes::Yes;
    if (taxSpecTmp)
        taxCode             = taxSpecTmp.TaxSpecCode;
        taxDirection        = taxSpecTmp.TaxDirection;
        taxWriteCode        = taxSpecTmp.PrintCode; /* используем невыбранный PrintCode*/
        taxExemptTax        = taxSpecTmp.ExemptTax;
        taxExemptCode       = taxSpecTmp.ExemptCode;
        currencyCode        = taxSpecTmp.SourceCurrencyCode;
        taxExemptDescription    = '';
Для сравнения можно посмотреть класс TaxInvoiceSpec метод taxSpec(), который выполняет аналог. функции и не содержит этих багов.
Как получить из стандарта: Распечатать подтверждение заказа (отчет salesConfirm) - не будут напечатаны налоговые коды (если они были заданы), при печати накладной коды печатаются.
баг, налоги, ошибка, ax2009
Проблема печати Штрих-кода Hammer DAX: Программирование 22 31.08.2012 13:22
Печать налогов в Торг-12 при типе налогового кода "Себестоимость" Sofya DAX: Функционал 1 24.11.2008 14:36
Баг(или не досмотрел) при печати счета-фактуры Lemming DAX: Программирование 0 18.11.2005 13:33
проблема с настройкой штрихового кода Nic DAX: Функционал 4 27.12.2004 09:04
Использование штрихового кода (barcode) в Аксапта Pavlo AKA Panok DAX: Функционал 9 17.10.2003 15:13
Часовой пояс GMT +3, время: 14:24.
