Старый 15.04.2009, 10:05   #1
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 1 is available on Partner Source and Customer Source!
Источник: http://blogs.technet.com/dynamicsaxs...er-source.aspx
To assist our partners and customers in their new Microsoft Dynamics AX deployments, the SE team started releasing roll-ups for Microsoft Dynamics AX 2009 RTM and SP1 platforms. The roll-ups aim to provide an easy way of deploying Microsoft Dynamics AX with the latest hotfixes on a given Service Pack level. The first roll-up packages for AX2009 RTM and SP1 have been available on Partner Source and Customer Source since mid-March and we have been seeing hundreds of downloads. Please find the roll-up KB articles below:
Roll-up
KB Number
Package Size
Dynamics AX 2009 RTM RU-1 KB Article
KB967146
~60MB
Dynamics AX 2009 SP1 RU-1 KB Article
KB967145
~75MB
There will be one roll-up package for each Service Pack level. Each roll-up will carry all previously released hotfixes and updates up to one month prior to the release of the roll-up. Each roll-up will be cumulative and will not require the presence of the previous roll-up on the system. The roll-ups will also carry the tax updates that have been released previously.
The roll-up package will contain both a cumulative kernel update and a cumulative application update. Although there is no dependency between these two updates, we recommend that you install both of the updates together. The roll-up will be installed on P-layers (i.e. SYP and GLP) and update the SYS layer as well as the GLS layer that is installed on the system.
Moving forward, the roll-ups will be announced at least one month prior to the release date. Currently, SE team is working on the plans for roll-up 2.
daxis: What’s new in Set based operations in Dynamics Ax 2009 Blog bot DAX Blogs 0 01.04.2009 18:05
Dynamics AX: Microsoft Dynamics BI - 'BI for the masses' Blog bot DAX Blogs 0 29.01.2009 02:20
DynamicsAxSCM: Quality Management in Dynamics AX 2009 - Upgrade essentials Blog bot DAX Blogs 0 16.12.2008 14:05
Dynamics AX: AMR Research: Awakening a Sleeping Giant - Inside Microsoft Business Solutions' ERP Strategy Blog bot DAX Blogs 0 22.09.2008 22:05
Часовой пояс GMT +3, время: 18:36.
