Старый 07.05.2009, 08:05   #1
Microsoft Dynamics CRM Team Blog: Dynamics CRM Online Picklists and Custom Entities
Источник: http://blogs.msdn.com/crm/archive/20...-entities.aspx
The purpose of a dynamic pick list is to allow you to make modifications to the list with as little impact as possible. Static list are effective for data that doesn't change often. For list values that need updating, a dynamic pick list is the trick. In addition, you could use the same technique to pull data from external systems and make available in the list.
The method I'll describe is pretty well known ( see www.stunnware.com as well). I thought it'd be good to revisit and put it up on the blog.
This method uses a custom entity to hold the values for the picklist and JScript to load the values into the picklist when the form loads. The JScript will query the data using the CRM web services. You could just as easily call into other web services that return data from external systems or have the custom entity that holds the data get update externally as well.
Read more at the Microsoft Dynamics CRM Online Team blog.
Cheers,
Jon White
Microsoft Dynamics CRM Team Blog: Lead Assignment, Territory Management and follow-up Blog bot Dynamics CRM: Blogs 0 02.04.2009 02:05
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Часовой пояс GMT +3, время: 08:37.
