Старый 24.07.2009, 04:20   #1
25,644 / 848 (80) +++++++
lcash: ProjPost Class compile error
Источник: http://blogs.msdn.com/lcash/archive/...ile-error.aspx
If you are using the AX 2009 Refresh 2 demo VM you may want to correct a line of code in the ProjPost class if you are using Projects and Project Time Sheets.
1. Press CRTL+D to open the AOT. Expand Classes.
2. Navigate down to ProjPost.
3. Expand to show the ClassDeclaration.
4. Right Click on ClassDeclaration. Select Compare.
5. When the compare tool opens. Click the Compare button to compare the default USR layer to the SYP layer.
6. This will show one line of code that needs to be in the USR layer. Which is a variable declaration for “skipCheckLedgerTransDate”. Click the Arrow control to add that to the USR layer. The colour will change from blue.
7. Close the Compare window. Click Save and Click Compile from the AOT toolbar.
8. The code should now compile without error.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash/
lcash: EP Development on VM – HTTP 401 Unauthorized error Blog bot DAX Blogs 0 03.07.2009 08:05
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 23:43.
