Старый 13.08.2009, 15:05   #1
25,644 / 848 (80) +++++++
CRM DE LA CREME! Installing CRM 3.0 in a SQL instance
Источник: http://crmdelacreme.blogspot.com/200...-instance.html
If you want to use CRM 3.0 with a named SQL instance you first have to disable the Environmental Diagnostics Wizard (EDW). How to do this? I couldn’t find a way except for a couple blogs/newsgroups pointing me to a support call with Microsoft. The Microsoft CRM Support Team might not like me posting this simple solution, but I think it is crazy that we got charged a support call for something like this and hopefully my post can prevent someone else from being on hold for two hours.
To disable it, you simply open RegEdit on the CRM server, browse to the MSCRM key at HKEY_LOCAL_MACHINE -> SOFTWARE -> Microsoft -> MSCRM and add the DWORD “IgnoreChecks” and give a value of 1.
You will have to reinstall CRM on the box and reconfigure what SQL server/instance you want to use there. You will get to the screen that has the warnings/errors, and the SQL line item will still give you an warning/error, but with the registry edit you can still click the Next button to proceed (without EDW disabled you can’t proceed). After finishing the install you can delete the registry entry you added.
CRM DE LA CREME! Three Top Tips for CRM 4.0 Plugin Development Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Microsoft Dynamics CRM Team Blog: How it Works: SQL Server Reporting Services and Dynamics CRM Blog bot Dynamics CRM: Blogs 0 19.07.2008 04:42
Часовой пояс GMT +3, время: 02:53.
