Старый 09.01.2010, 05:05   #1
emeadaxsupport: Error when deploying ODC files: Development site is not found in the EPParameters table
Источник: http://blogs.msdn.com/emeadaxsupport...ers-table.aspx
We recently came across and issue where when we click on the "Deploy ODC" button in the OLAP Administration form in AX 2009 client (AX 2009 -> Administration -> Setup -> Business Analysis -> OLAP -> OLAP Administration)
we get the following error in InfoLog:
"Development site is not found in the EPParameters table"
The reason is that In order to deploy the ODC files successfully an Enterprise Portal site must have been installed successfully and registered in the Web Sites form (AX 2009 -> Administration -> Setup -> Internet ->
Enterprise Portal -> Web Sites). The ODC deployment uses the Enterprise Portal web site listed in the box under "Site called by the Application Object Tree for Web development" to determine where to deploy the .odc files to. If this section is empty and/or if the url specified is inaccessible or incorrect then this is one of the reasons why you may get the error message shown in the InfoLog
Further Info:
By default the ODC files are deployed to the /Data Connections". ODC files are used by web parts that require a connection to the OLAP server and database, for example to display KPIs in Role Centers.
See the attachment which includes screenshots of the errors and forms mentioned.
Solutions Monkey: 64bit machine - VS EP add-in not deploying user control to SharePoint while saving Blog bot DAX Blogs 0 06.01.2010 08:19
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
jerry-dynamics: How can you make sure that the end user can not delete a record in one table if there are related records in another table? Blog bot DAX Blogs 0 16.06.2007 11:20
Solutions Monkey: EP Site Templates not appearing under "Custom Tab" in WSS 3.0/MOSS 2007 Blog bot DAX Blogs 0 14.06.2007 03:52
Часовой пояс GMT +3, время: 03:02.
