Старый 04.03.2010, 10:01   #1
Kipetcoff is offline
Kipetcoff
Отправка писем из плагина
Создал плагин,который повесил на создание сущности. Пытаюсь отправить писма из него. Письма создаются,но не отправляются. Я раньше отправлял письма из кода моей страницыи все было прекрасно,теперь этот же код не работает.
InstantiateTemplateResponse instTemplateResponse = (InstantiateTemplateResponse)crmService.Execute(instTemplate);
						email emailCreate = (email)instTemplateResponse.BusinessEntityCollection.BusinessEntities[0];
						emailCreate.regardingobjectid = new Lookup();
						emailCreate.regardingobjectid.type = sContentType;
						emailCreate.regardingobjectid.Value = new Guid(sEntId);
						//specify the owner for the mail
						emailCreate.ownerid = new Owner();
						emailCreate.ownerid.type = EntityName.systemuser.ToString();
						emailCreate.ownerid.Value = userid;
						//created by
						emailCreate.createdby = new Lookup();
						emailCreate.createdby.type = EntityName.systemuser.ToString();
						emailCreate.createdby.Value = userid;
						activityparty apTo = new activityparty();
						apTo.partyid = new Lookup();
						apTo.partyid.type = sContentType;
						apTo.partyid.Value = new Guid(sEntId);
						emailCreate.to = new activityparty[] { apTo };
						// specify the from part of the email
						activityparty from = new activityparty();
						from.partyid = new Lookup();
						from.partyid.type = EntityName.systemuser.ToString();
						from.partyid.Value = userid;
						emailCreate.from = new activityparty[] { from };
						Guid emailId = crmService.Create(emailCreate);
						//attachment
						foreach (object oAttach in arrAttBodies)
							activitymimeattachment attachment = new activitymimeattachment();
							try
								annotation annot = (annotation)oAttach;
								if (annot != null)
									attachment.activityid = new Lookup();
									attachment.activityid.Value = emailId;
									attachment.activityid.type = EntityName.email.ToString();
									attachment.filename = annot.filename;
									attachment.body = annot.documentbody;
									attachment.mimetype = annot.mimetype;
									Guid attachmentId = crmService.Create(attachment);
							catch (System.Web.Services.Protocols.SoapException ex)
								//ErrorMessage("Create Attachments Error:" + ex.Detail.InnerText);
						//Send the Email
						try
							// Create an SendEmailRequest object
							SendEmailRequest req = new SendEmailRequest();
							req.EmailId = emailId;
							req.TrackingToken = "";
							req.IssueSend = true;
							// Finally Send the email message.
							SendEmailResponse res = (SendEmailResponse)crmService.Execute(req);
							iMailsCnt++;
							if (!bResult)
								bResult = true;
							//ErrorMessage("Send Mail Error:" + ex.Detail.InnerText);
Письма создаются,но они по запросу SendEmailResponse не отправляются...они висят пока его не откроешь и не отправишь вручную.
Единственную разницу которую мне удалось найти это то,что в поле Createdby теперь значение SYSTEM,хотя раньше туда писался пользователь под которым создавались письма.
Ошибка ни о чем "0x80040216 An unexpected error occurred. Platform"
Вопрос вобщем-то простой WTF?
Старый 04.03.2010, 10:07   #2
slivka_83 is offline
slivka_83
Консультант-джедай
Аватар для slivka_83
1,683 / 374 (16) ++++++
А как Вы создаете crmService?
Экстремал и буду экстремать!
Блога
За это сообщение автора поблагодарили: Kipetcoff (1).
Старый 04.03.2010, 10:46   #3
Kipetcoff
CrmAuthenticationToken token = new CrmAuthenticationToken();
					token.OrganizationName = sOrgan;
					token.AuthenticationType = 0;
					//Create the Service
					CrmService crmService = new CrmService();
					crmService.Credentials = System.Net.CredentialCache.DefaultCredentials;
					crmService.PreAuthenticate = false;
					crmService.CrmAuthenticationTokenValue = token;
					crmService.Url = (string)(Registry.LocalMachine.OpenSubKey("Software\\Microsoft\\MSCRM").GetValue("ServerUrl")) + "/2007/crmservice.asmx";
Старый 04.03.2010, 11:11   #4
Kipetcoff
Вы абсолютно правы..дело было в методе создания сервиса...
Правильно
ICrmService crmservice = context.CreateCrmService(true);
Старый 27.05.2010, 17:28   #5
Skyway is offline
Skyway
Примерно то же самое
                    email emailCreate = new email();
                    emailCreate.regardingobjectid.type = "new_business_trip";
                    emailCreate.regardingobjectid.Value = target.EntityId;
                    emailCreate.ownerid.Value = new Guid("9D5BF1D0-1D80-DE11-9267-000E0C4BF7BF");
                    //created by
                    emailCreate.createdby.Value = new Guid("9D5BF1D0-1D80-DE11-9267-000E0C4BF7BF");
                    apTo.partyid.type = EntityName.systemuser.ToString();
                    apTo.partyid.Value = new Guid("9D5BF1D0-1D80-DE11-9267-000E0C4BF7BF");
                    from.partyid.Value = new Guid("9D5BF1D0-1D80-DE11-9267-000E0C4BF7BF");
                    emailCreate.subject = "Заявка на командировку";
                    emailCreate.description = "Вам отправлена заявка на командировку. Для просмотра и возможного изменения заявки перейдите в Microsoft Dynamics CRM, надстройка Командировки.";
                    Guid emailId = Crmservice11.Create(emailCreate);
                    //Send the Email
                    try
                        req.TrackingToken ="";
                        Crmservice11.Execute(req);
Письмо создается, но не отправляется, ругается кажется на req.TrackingToken ="";
Ошибка: недопустимый аргумент
Старый 28.05.2010, 11:42   #6
Гуревич Денис is offline
Гуревич Денис
228 / 67 (3) ++++
Сообщение от Skyway Посмотреть сообщение
В Trace смотрите более подробную инфу по ошибке.
Вы этот код из плагина вызываете?
Опыт позволяет ошибаться гораздо увереннее.
Старый 31.05.2010, 16:13   #7
Skyway is offline
Skyway
Да, из плагина
Походу какой-то глюк был. Скопировал код в новый проект и все заработало...
Старый 13.03.2014, 19:19   #8
b777 is offline
b777
Всем привет!
Тоже создаю письма из плагина. Отправляются нормально, но как сделать, чтоб ссылки были "кликабельными"?
Сейчас видна голый текст вида http:\\... без преобразования в ссылку.
Где-то нужно ещё задать какую-то настройку, свойство, чтоб сообщить о том, чтобы письмо было HTML-ного формата или сам текст письма надо ещё как-то кодировать, и одного SecurityElement.Escape мало?
Старый 13.03.2014, 20:43   #9
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Попробуйте добавлять ссылку не просто текстом, а в html формате вроде
<a href='http://google.com'>Click to opne google</a>
Старый 14.03.2014, 10:04   #10
b777 is offline
b777
Пробовал. Именно так она и отображается, в виде HTML-разметки.
Старый 14.03.2014, 11:14   #11
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Сообщение от b777 Посмотреть сообщение
У меня такой подход работает. Видимо проблема в клиенте, которым вы проверяете почту.
Старый 14.03.2014, 12:05   #12
b777 is offline
b777
Проверяю outlook-ом.
Но дело в том, что в самом CRM в карточке письма ссылка тоже должна быть кликабельной.
Может в параметрах самого SendMailRequest-а какие-то свойства указывать необходимо?
Проблема с русским текстом в теле писем после обработки E-mail Router SeregaK Dynamics CRM: Администрирование 10 21.02.2012 10:05
Привязывание писем к сущностям Казарин Александр Dynamics CRM: Функционал 4 18.08.2009 16:38
Модификая контекста плагина ZooY Dynamics CRM: Разработка 3 28.09.2008 13:52
Отправка писем из MS CRM xxxxsoft Dynamics CRM: Функционал 2 10.10.2007 14:30
Время получения и отправления писем Boris Ilyin Dynamics CRM: Функционал 0 24.05.2007 12:54
Часовой пояс GMT +3, время: 11:39.
