Старый 21.04.2010, 18:05   #1
kamalblogs: Grouping orders in Master planning
Источник: http://kamalblogs.wordpress.com/2010...ster-planning/
In the Dimension group setup there is on options “Coverage plan by dimension”
(click to enlarge)
This dimension setup decides how issues are grouped based on dimensions
But just this setup wouldn’t be enough to achieve grouping when you run the scheduling engine.
Make sure you also setup the “Coverage code” in the Item Coverage group to “Period”. If  this setup is not done then you will still find issues getting created individually or based on Min Max
Once you have both in place, then the grouping starts working based on the “coverage plan by dimension” setup.
kamalblogs: Towards Dynamics Ax Product Certification – Best Practices (Part I) Blog bot DAX Blogs 2 21.02.2012 12:57
kamalblogs: Adding custom images for Treenode in Dynamics Ax Blog bot DAX Blogs 0 25.01.2010 17:05
kamalblogs: I 4 C For Dynamics Ax:) Blog bot DAX Blogs 0 25.01.2010 17:05
ReqCalc класса и Master Planning ... Rimantas DAX: Программирование 13 03.08.2007 08:58
Отличия в строках ReqPO, почему одна строка появляется в форме а другая нет (Master Planning, Planned Orders) rkorchagin DAX: Программирование 8 21.02.2007 16:27
Часовой пояс GMT +3, время: 01:03.
