Старый 14.12.2010, 11:58   #1
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Post Not Able To Install Microsoft Dynamics AX 2009 On A Windows 7 Workstation
Дата изменения 03.11.2010
Отправлено 14.07.2010
Microsoft Dynamics AX 2009 client installation fails
Summary
Not able to install Dynamics AX 2009 client on some Windows 7 machines. You will see error simillar to this in the DynamicsSetupLog file -
RegAsm : error RA0000 : Could not load file or assembly 'System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
>>Install: During Setup of an error occurred. Program run: C:\Windows\Microsoft.NET\Framework\v4.0.30319\regasm.exe. Parameters: C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.dll /unregister
>>Install: Registering or configuring file: C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.dll
>>Install: C:\Windows\Microsoft.NET\Framework\v4.0.30319\regasm.exe C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.dll /tlb /codebase
>>Install: Microsoft (R) .NET Framework Assembly Registration Utility 4.0.30319.1
Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
Cause:
Only the Microsoft .NET Framework 4 Client Profile is installed on the workstation. This is an optional update that is now available through Windows Update (KB982670). If you only have this installed you will NOT be able to install the AX 2009 client.
Resolution:
1. Uninstall Microsoft .NET Framework 4 Client Profile then install AX 2009 client. You may then re-apply KB982670.
OR
2. Install Microsoft .NET Framework 4 also then install AX 2009.
Partnersource: Not Able To Install Microsoft Dynamics AX 2009 On A Windows 7 Workstation
Customersource: Not Able To Install Microsoft Dynamics AX 2009 On A Windows 7 Workstation
Knowledgebase: Microsoft Dynamics AX 2009 Client installation fails on Windows 7 32-bit workstation (KB2290614)
Последний раз редактировалось Poleax; 14.12.2010 в 12:01.
За это сообщение автора поблагодарили: Damn (2), Logger (3).
ax2009, error, framework, windows 7
dynamics-ax: Interview with Microsoft's Lachlan Cash about Dynamics AX Technical Conference Blog bot DAX Blogs 0 28.09.2010 01:05
emeadaxsupport: Starting Dynamics AX 2009 is launching Windows Installer for Microsoft Axapta 3.0 Blog bot DAX Blogs 0 27.01.2010 13:05
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Dynamics AX: Migration Tool for Microsoft Dynamics AX 2009 - Release Blog bot DAX Blogs 0 25.11.2008 02:08
Часовой пояс GMT +3, время: 05:58.
