Старый 25.01.2011, 02:12   #1
Microsoft Dynamics CRM Team Blog: Enhanced capabilities and new UI experience of Article (KB Article) in CRM 2011
Источник: http://blogs.msdn.com/b/crm/archive/...-crm-2011.aspx
In Microsoft Dynamics CRM, an article or knowledge base article is a type of structured content that is managed internally as part of a knowledge base. Using Articles, users can manage product/service information of business unit, FAQs and other information. When you create an article you have to associate it with KB Article template and a subject. The template describes pre-defined formatting and the sections that can be used in your article.
Subjects are used to organize the articles by business categories. In Microsoft Dynamics CRM 2011 the UI experience of article grid and form is enhanced by adding customization capabilities to article entity, makings its grid and form experience native to CRM and associating its search experience with quick find control and ribbon. These changes give user enhanced capabilities and smooth UI experience.
Customization capabilities of Article:
In Microsoft Dynamics CRM 2011 the Article entity is opened for customizations. User has following capabilities on customization with article:
  • Customize Article form
  • Views
  • Charts
  • Fields
  • 1: N relationship
  • N: 1 Relationship
  • N: N relationship
  • Messages
Article has Language:
A new field languagecode is added to article entity. Its value is automatically set based on language of article template. This field is by default added on article form and grid. With this user can define views and add filters on default view based on language.
Article Form:
Article Grid and Form in CRM 2011:
The Article grid and form is ribbonized like most of other entities in Microsoft Dynamics CRM 2011. All the controls which were in toolbar are moved to ribbon. To navigate to article grids there are two OOB navigations provided.
1. Workplace > My Work > Articles
2. Service > Articles
Both grids are identical. Please note that there is a difference in these grids from Microsoft Dynamics CRM 4. 0. On the CRM 4.0 Workplace > Article there was search experience on grid and it used to show published articles. From the Workplace it used to always open article in article viewer. By default, Microsoft Dynamics CRM 2011 opens the CRM form. If user wants to open it in article viewer user have to explicitly open it by selecting published article from grid and clicking “View in HTML”.
Microsoft Dynamics CRM 4:
Workplace > Article
Microsoft Dynamics CRM 2011:
Workplace > Article
New Search Experience: Ribbon and Quick find supported
In CRM 4 the search experience was associated with grid. There was a separate column on grid where user had capabilities to define search criteria.
In CRM 2011 to make article grid experience more native these search options are now available on a new ribbon tab. This tab comes on focus when user clicks on quick find.
User needs to mention search text in quick find. Search functionality is similar to CRM 4.0 only the UI experience has been changed. We support following Search options:
  • Full text search
  • Keyword Search
  • Title Search
  • Subject Search
  • Article Number Search
Following search types are supported:
  • Exact Words
  • Use like Words
The Subject can be mentioned by clicking on subject button which opens subject lookup and then selecting subject from lookup. If user want to close search tab than click on Close search. The Search experience is similar to that of the Outlook CRM client. I would like you to walk through an example which will explain new search experience in more detail. For example, if user want to do a Title search on “Web Browser” with search type of ‘Use Like Words’ and filter on subject “Default Subject”. Then the steps for the user would be:
1. Click on ‘Quick Find’. (That will bring Search tab in focus.)
2. Type search text in ‘quick find’. For the above example it is “Web Browser”
3. Select “Title search” from search options and “Use Like words” from search type
4. Click on Subject.
5. Select the Subject from lookup results.
6. Click on Find button next to quick find text box.
You can now see the search results in this resulting grid.
Cheers,
Niraj Yadav
Часовой пояс GMT +3, время: 19:33.
