Старый 18.03.2011, 20:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Some reports from Reporting extensions can raise error when running on SQL 2008 R2
Источник: http://blogs.msdn.com/b/emeadaxsuppo...l-2008-r2.aspx
Thanks to our colleague in Japan we found problem when running some Dynamics AX reporting extensions report on SQL 2008 R2.
When we open some standard SSRS reports with SQL2008R2 (ie. TSInvoicedPurchaseAmount.TS_InvoicedPurchaseAmountDetail.Report ), we receive following error.
An error has occurred during report processing. (rsProcessingAborted)
Query execution failed for dataset 'InvoiceAmountDetailedReport'. (rsErrorExecutingCommand)
Query (58, 19) Parser: The syntax for 'Item' is incorrect.
This is because the Item is reserved word of MDX and execution is causing the error. So to fix the problem we need to change parameter name for DataSet 'InvoiceAmountDetailedReport'.
Fortunately there are already hotfixes which fixed this problems:
KB2519061
TSInvoicedPurchaseAmount.TS_InvoicedPurchaseAmountWebpart.Report
KB2520255
ProjCashFlow.ProjActualvsBudgetNetCashflow.XYChart
ProjCostControl.ProjTotalBudgetCost.LineChart
ProjHourUtilization.ProjUtilizationEfficiency.XYChart
ProjStatements.ProjActualvsBudgetConsumption.XYChart
ProjStatements.ProjActualvsBudgetCost.XYChart
ProjStatements.ProjActualvsBudgetGrossMargin.XYChart
ProjStatements.ProjActualvsBudgetNetWIP.XYChart
ProjStatements.ProjActualvsBudgetPayroll.XYChart
ProjStatements.ProjActualvsBudgetRevenue.XYChart
Right now both hotfixes are not published so please contact Support Team to get both hotfixes.
--author:Yuji Imaoka
--editor:Czesława Langowska
--date:18/March/2011
Последний раз редактировалось Poleax; 19.03.2011 в 13:03.
emeadaxsupport: Reporting Extensions Installation Fails to install on SQL 2008 Reporting services after applying 959494 and 957312 Blog bot DAX Blogs 1 23.06.2011 14:27
emeadaxsupport: AX 2009 Setup fails to install IIS Components on Windows Server 2008 R2 Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 10:00.
