#1 |
sumitsaxfactor: Handling RecIds in SQL Server
Источник: http://sumitsaxfactor.wordpress.com/...in-sql-server/
============== I have already written one article on handling RecIds in AX (click here to read it). There I have mentioned a method to handle RecIds using SQL. I am writing this article after actually implementing it ![]() The need arose because we had some recalculations and data inserts required for one of our clients (almost more than 2 million records). Last time when we had run the script to perform this task in AX, it took us 4 days to complete the whole task. So we decided to try and perform these tasks using SQL Scripts for better performance. I am not writing that script here but I will take an example and explain you how we can handle RecIds through SQL Server. Let us assume that we need to backup current customer master to a new table. For this purpose I created a new table named SGXCustTable with following fields:
X++: DECLARE @NEXTVAL BIGINT, @ROWCOUNT BIGINT, @NEXTVALTRANS BIGINT DROP TABLE #TEMP First insert all the required data into a temporary table with RecId as an identity field Note: *CreatedTime and ModifiedTime are stored as integers hence convert them to corresponding integer *RecId field is made as an identity field that will be used later for calculating Record Ids *GETDATE() when used with date field automatically converts to date and with datetime field automatically gets datetime SELECT [ACCOUNTNUM], [NAME], [MODIFIEDTIME]=(DATEPART(hour, GETDATE()) * 3600)+(DATEPART(MINUTE, GETDATE()) * 60)+DATEPART(SECOND, GETDATE()), [CREATEDTIME]=(DATEPART(hour, GETDATE()) * 3600)+(DATEPART(MINUTE, GETDATE()) * 60)+DATEPART(SECOND, GETDATE()), [CREATEDDATE]=GETDATE(),[MODIFIEDDATE]=GETDATE(), [CREATEDDATETIME],[MODIFIEDDATETIME], [CREATEDTRANSACTIONID]=0,[MODIFIEDTRANSACTIONID]=0,[CREATEDBY]=,[MODIFIEDBY]=, [DATAAREAID], [RECVERSION], [RECID] = IDENTITY(BIGINT,0,1) INTO #TEMP FROM CUSTTABLE WHERE CUSTTABLE.DATAAREAID = The Next RecId value is stored in SystemSequences Table Get the Next RecId and store it in a variable Note the TABID will be the table id into which records are being inserted SELECT @NEXTVAL=NEXTVAL FROM SYSTEMSEQUENCES WITH(UPDLOCK, HOLDLOCK) WHERE ID = -1 AND TABID = 50051 Note that this is required for ModifiedTransactionId and CreatedTransactionId The sequence for this is stored per company with TABID as 0 (Independent of tables) and ID = -2 SELECT @NEXTVALTRANS=NEXTVAL FROM SYSTEMSEQUENCES WITH(UPDLOCK, HOLDLOCK) WHERE TABID = 0 AND ID = -2 Now read all the records from temporary table and insert into the required table Note that RecId, CreatedTransactionId and ModifiedTransactionId are made using the NextVal fetched from SystemSequences and Identity column INSERT INTO SGXCUSTTABLE (ACCOUNTNO, NAME, MODIFIEDTIME, CREATEDTIME, CREATEDDATE, MODIFIEDDATE, CREATEDDATETIME, MODIFIEDDATETIME, CREATEDTRANSACTIONID, MODIFIEDTRANSACTIONID, CREATEDBY, MODIFIEDBY, DATAAREAID, RECVERSION, RECID) SELECT [ACCOUNTNUM], [NAME], [MODIFIEDTIME],[CREATEDTIME],[CREATEDDATE],[MODIFIEDDATE],[CREATEDDATETIME], [MODIFIEDDATETIME],[CREATEDTRANSACTIONID]=@NEXTVALTRANS+[RECID],[MODIFIEDTRANSACTIONID]=@NEXTVALTRANS+[RECID], [CREATEDBY],[MODIFIEDBY], [DATAAREAID], [RECVERSION],[RECID] = @NEXTVAL + [RECID] FROM #TEMP Select the number of records inserted SELECT @ROWCOUNT = COUNT(*) FROM #TEMP Update the used number sequences back to SystemSequences table UPDATE SYSTEMSEQUENCES SET NEXTVAL=NEXTVAL + @ROWCOUNT WHERE ID = -1 AND TABID = 50051 UPDATE SYSTEMSEQUENCES SET NEXTVAL=NEXTVAL + @ROWCOUNT WHERE TABID = 0 AND ID = -2 AND DATAAREAID = SELECT * FROM SGXCUSTTABLE ![]() Источник: http://sumitsaxfactor.wordpress.com/...in-sql-server/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
