Старый 27.04.2011, 22:11   #1
emeadaxsupport: Printer defaults to letter instead of A4 - how AX finds the default printer
Источник: http://blogs.msdn.com/b/emeadaxsuppo...t-printer.aspx
The issue here is that printing an X++ report to file (pdf) via a business connector call within a web service, the paper size is defaulting to "letter" instead of the usual A4 size we use in Europe, but we'll also explain first how AX finds the default printer and then we'll talk about how that applies in our problem situation.
How the AX kernel finds the default printer:
What is happening in the background here is that the AX kernel calls into the Windows function GetDefaultPrinter() (http://msdn.microsoft.com/en-us/libr...76(VS.85).aspx) this looks to the registry key:
.. Software\Microsoft\Windows NT\CurrentVersion\Windows\Device
To find the default printer, whether this is HKCU, HKU\UserSid, or HKU\Default depends on the context it is running in and whether the particular user profile actually exists or not. Once the function finds the device from here it will move to the registry key:
..Software\Microsoft\Windows NT\CurrentVersion\Devices\
Later in the kernel we'll use the Windows function OpenPrinter() (http://msdn.microsoft.com/en-us/libr...51(VS.85).aspx) to access the printer's properties - this is where the papersize would be populated. If this function fails, and if not printing direct to that device (e.g. print to file/screen etc..) then we'll set a pseudo-printer with some standard defaults to allow printing to continue even though we cannot access the printer. This pseudo-printer uses "letter" page size, so this is where that is coming from.
The reason that we have this pseudo-printer mechanism is that when running BC under w3wp it is not always possible to access printer information - we created it during the development of AX4 as part of the new .NET business connector and Enterprise portal framework, without this mechanism, with certain configuration it is possible that we would fail in low level printer functions which the reporting engine relies upon.
Why in some situations we fail to find the default printer:
Now if I apply this to a specific situation, for example we may be running the business connector within a web service, which runs as the ApplicationPoolIdentity. So when we call GetDefaultPrinter() - we find there is no user profile for that identity (it is not access denied - it simply does not exist) this can be seen with a procmon trace from a line like this:
12:34:23.5536848 PM w3wp.exe 2676 RegOpenKey HKU\S-1-5-82-2257762870-3033483361-1282393911-956591122-915368935 NAME NOT FOUND Desired Access: Read
Next we jump to the default user profile, which does exist, but the key that we need does not exist, which basically tell us there is no default printer for the default user profile:
12:34:23.5537105 PM w3wp.exe 2676 RegOpenKey HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\Windows NAME NOT FOUND Desired Access: Read
From this point onwards - as we found no printer in the steps above, we fail to return a default printer, and therefore when we call openPrinter we also fail and the pseudo-printer is selected instead - and the pseudo printer has "letter" papers size instead of A4.
To move past this you need to run the application pool as a domain account, and ensure that it has access to pick up a real printer - you can test with procmon as I described above to see where it's looking for the printer so that you can prove where it's failing.
--author: Tariq Bell--editor: Tariq Bell--date: 27/04/2011
За это сообщение автора поблагодарили: alex55 (1).
emeadaxsupport: How to add financial dimension to Dynamics AX Default cubes Blog bot DAX Blogs 0 13.01.2011 16:11
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
Часовой пояс GMT +3, время: 08:44.
