Старый 19.08.2011, 22:12   #1
25,644 / 848 (80) +++++++
Dynamics AXBR: AX 2012 – Development I & Development II
Источник: http://feedproxy.google.com/~r/daxbr/~3/Ij13Hws-Txc/
Caros,
Seguem os links para os Training Materials:
Development I in Microsoft Dynamics AX 2012
  • Describe the basic features of Microsoft Dynamics AX 2012.
  • Review basic form navigation.
  • Review the architecture of Microsoft Dynamics AX 2012.
  • Describe the options for making development changes in Microsoft Dynamics AX 2012.
  • Describe the theory of Model Driven Architecture in Microsoft Dynamics AX 2012.
  • Review licensing and configuration.
  • Explain the MorphX development environment and the Application Object Tree.
  • Design tables using MorphX.
  • Describe the different data types within Microsoft Dynamics AX.
  • Create a new table.
  • Learn how to create and modify indexes using MorphX.
  • Describe relations on Microsoft Dynamics AX tables.
  • Learn how to create and modify Enumerated data types.
  • Learn how to create and modify views.
  • Design and build Forms in Microsoft Dynamics AX.
  • Join two data sources on a form.
  • Create customized menus and menu items.
  • Create a form using form templates.
  • Know the components of a list page.
  • Create a new FactBox.
  • Describe the elements of Role Based Security in Microsoft Dynamics AX.
  • Setup a new user.
  • Assign roles to a user.
  • Assign a security role to a user.
  • Edit duties assigned to a role.
  • Edit privileges assigned to a duty.
  • Edit permissions assigned to a privilege.
  • Search for roles with access to a menu item.
Development II in Microsoft Dynamics AX 2012
  • Identify key features of developing with X++.
  • Describe the basic foundation of object-oriented programming.
  • Use the development tools available within Microsoft Dynamics AX 2012.
  • Create object and data models from existing application elements by using the Reverse Engineering tool.
  • Use best practices to instill good programming habits.
  • Declare and use extended data types for variables.
  • Use the various operators available in X++.
  • Control program flow using conditional statements in X++.
  • Repetitively call the same blocks of code by using Loop statements.
  • Use standard functions that are built in to the application.
  • Use output commands to display data and messages to the user.
  • Use the classes within Microsoft Dynamics AX 2012 X++ development.
  • Control access to methods using Access Control Method Modifiers.
  • Extend a class using the concept of inheritance.
  • Describe the differences between an object and a class.
  • Initialize variables in the appropriate place according to scoping rules.
  • Call methods within the same class.
  • Use the different method types available.
  • Describe the similarities and differences between tables and classes.
  • Use the eventing publisher and subscriber model when modifying code in the application.
  • Retrieve data from the database using a select statement.
  • Create, update and delete data in the database.
  • Use and build queries using kernel classes.
  • Examine the exception handling mechanism in Microsoft Dynamics AX.
  • Use the Try, Catch, and Retry statements.
  • Throw an exception from code.
  • Identify and create code used to handle optimistic concurrency exceptions.
  • Set permissions on application elements.
  • Design and create security policies.
  • Secure unsafe Application Programming Interfaces (APIs) using the Code Access Security framework.
  • Authenticate data returned from display methods.
[]s
Pichler
Старый 20.08.2011, 13:27   #2
lvan is offline
lvan
Аватар для lvan
858 / 82 (4) ++++
Записей в блоге: 1
development 3 тоже выложен
https://mbs.microsoft.com/CMS/Templa...ACHEHINT=Guest
dynamics-ax: Microsoft Dynamics AX 2012 - Launch Event, Training Plans & WPC 2011 Blog bot DAX Blogs 0 13.07.2011 22:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 02:24.
