Старый 13.10.2011, 18:11   #1
emeadaxsupport: Unable to deploy AX 2012 default SRS reports
Источник: http://blogs.msdn.com/b/emeadaxsuppo...s-reports.aspx
Problem:
Recently we ran into a strange issue where we were unable to deploy the AX 2012 default SRS reports. Attempting to do so from the AX development client or through the AX management Shell returned the error below.
The network path was not found.
If User Account Control (UAC) is enabled on the machine, close the application, right-click the application, and then click Run as administrator.
Although the error suggest the issue to be caused by not having administrative permission when deploying the reports. We found this not to be the case.
Cause:
Through taking a network trace and reviewing the source code we found the issue to be caused by the "Remote Registry Service" being stopped.
Resolution:
After starting the "Remote Registry Service" through "Start/Administrative Tools/Services" deployment of AX 2012 default SRS reports was successful.
--author: Jago van der Most --editor: Jago van der Most --date: 13/Oct/2011 --last edited: 13/Oct/2011
Старый 13.10.2011, 22:05   #2
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,326 / 3556 (125) ++++++++++
Гыыыы.... как обычно UAC во всем виноват
The Edge: New Framework for Reports in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 03.08.2011 09:11
emeadaxsupport: Unable to deploy AX 2009 Enterprise Portal on SharePoint 2010 even after patching setup files with hotfix 2278963 Blog bot DAX Blogs 0 08.12.2010 03:14
emeadaxsupport: Unable to install Dynamics AX 2009 Analysis extensions when the default SQL Server Analysis Server collation is set to Turkish_CI_AS or Turkish_CS_AS Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 01:17.
