Старый 08.12.2011, 13:24   #1
Gogus is offline
Gogus
? CRM 4.0 Не удаляются сообщения эл. почты
Здравствуйте Уважаемые!
После переезда CRM c 3.0 на 4.0 перестали удаляться сообщения эл. почты, заказы, интересы...
"Плюется" ошибкой:
В ЛОГах ошибка .NET :
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 12/8/2011 12:43:24 PM
Event time (UTC): 12/8/2011 8:43:24 AM
Event ID: a9925f1e16ce4639b38c5be2e062c08a
Event sequence: 112621
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-5-129677621065374281
Trust level: Full
Application Virtual Path: /
Application Path: c:\inetpub\wwwroot\
Machine name: OMEGA
Process information:
Process ID: 4052
Process name: w3wp.exe
Account name: NT AUTHORITY\NETWORK SERVICE
Exception information:
Exception type: TargetInvocationException
Exception message: Exception has been thrown by the target of an invocation.
Request information:
Request URL: http://omega/МОЯОРГАНИЗАЦИЯ/_grid/cmds/dlg_delete.aspx?iObjType=4200&iTotal=1&iIndex=0&sSubTypes=4202&sSrcQueueId=&sParentId=&sCalendarId=&iId={BD4358FA-C90A-E111-B4C9-002618CA6464}
Request path: /МОЯОРГАНИЗАЦИЯ/_grid/cmds/dlg_delete.aspx
User host address: 192.168.5.22
User: МОЙДОМЕН\administrator
Is authenticated: True
Authentication Type: Negotiate
Thread account name: NT AUTHORITY\NETWORK SERVICE
Thread information:
Thread ID: 1
Is impersonating: False
Stack trace: at Microsoft.Crm.Application.Utility.Util.RaiseXMLError(Exception exception)
at Microsoft.Crm.Dialogs.DeleteDialogPage.ConfigureForm()
at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e)
at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Посоветуйте плиз "куда дальше рыть"?
Старый 08.12.2011, 13:55   #2
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Поднимите SQL Timeout. Как это сделано лписано тут - http://mscrmuk.blogspot.com/2008/09/...sql-error.html
Старый 08.12.2011, 14:35   #3
Gogus is offline
Gogus
Создал ключ (OLEDBTimeout) - поставил значение 60 перезапустил ИИС - не помогло...
Мне кажется SQL тут непричем... Ругаецца на .NET
Я в свойствах сайта, в свойствах АSP.NET изменил значение Request timedout - с 300 на 600 - тоже не помогает...
Старый 08.12.2011, 16:46   #4
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Включите трейс, перезапустите иис, воспроизведите ошибку, покажите лог, который появился - http://support.microsoft.com/kb/907490
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 4 Blog bot Dynamics CRM: Blogs 0 24.09.2011 01:16
Часовой пояс GMT +3, время: 20:34.
