Старый 18.01.2012, 11:11   #1
sumitsaxfactor: Replace a Financial Dimension in Default Dimensions [AX 2012]
Источник: http://sumitsaxfactor.wordpress.com/...sions-ax-2012/
In my earlier post, I had explained how we can set financial dimensions. In this post, I will provide a job by which we can replace one attribute value in a combination of financial dimensions.
The class that we can use is the DimensionDefaultingService and method to use is “serviceReplaceAttributeValue”.
For this purpose, we will use the following combination taken from a customer record.
In this financial dimensions, we will replace value if worker from “114” to “51011”.
The job below will be helpful for you to see how this can be achieved.
staticvoid replaceDefaultDimensions(Args _args)
    CustTable                       custTable = CustTable::find(‘CUS-00004′); //Customer Record containing Financial Dimension
    DimensionSHA1Hash               hash; //To store the calculated hash for DimensionAttributeValueSet
    DimensionAttribute              dimAttr; // Contains the financial dimensions records
    DimAttributeHcmWorker           dimAttrWorker; //Backing entity view for Employee type dimension
    DimensionDefault                defaultDimension;
    DimensionEnumeration            dimensionSetId; //Record id for table that contains active dimensions for current ledger
    DimensionAttributeValue         dimAttrValue; // Contains used financial dimension values
    DimensionAttributeValueSet      dimAttrValueSet; //Contains default dimension records
    DimensionAttributeValueSetItem  dimAttrValueSetItem; //Contains individual records for default dimensions
    DimensionAttributeSetItem       dimAttrSetItem; // Contains the number of dimensions active for a account structure ledger
    HashKey valueKeyHashArray[]; //To store the has key of dimension in question
    Map     dimAttrIdx, dimAttrRecId; //to store the dimension index and backing entity type
    int     dimAttrCount, i;
    int     emplBackEntityType; //Stores the backing entity type for Employee type dimension
    //The employee backing entity will be the view DimAttributeHcmWorker
    emplBackEntityType = tableNum(DimAttributeHcmWorker);
    //Initialize the map to store the backing entity types
    dimAttrIdx = new Map(Types::Integer, Types::Integer);
    dimAttrRecId = new Map(Types::Integer, Types::Int64);
    //Get the record Id (dimension set id) for current ledger to find active dimensions
    dimensionSetId = DimensionCache::getDimensionAttributeSetForLedger();
    //Find all the active dimensions for current ledger except main account and store there
    //backing entity type in the map
    whileselect * from dimAttr
            orderby Name
            where dimAttr.Type != DimensionAttributeType::MainAccount
        join RecId from dimAttrSetItem
            where dimAttrSetItem.DimensionAttribute == dimAttr.RecId &&
                dimAttrSetItem.DimensionAttributeSet == dimensionSetId
        dimAttrCount++;
        dimAttrIdx.insert(dimAttr.BackingEntityType, dimAttrCount);
        dimAttrRecId.insert(dimAttr.BackingEntityType, dimAttr.RecId);
    //Get the backing entity type for the dimension value to process
    selectfirstOnly dimAttrWorker
        where dimAttrWorker.Value == "51011";
    //initialize hash key array to null
<span><font face="Consolas"><font size="2">    for (i = 1<font color="#000000">; i
sumitsaxfactor: Defaulting Financial Dimensions [AX 2012] Blog bot DAX Blogs 0 28.12.2011 19:11
emeadaxsupport: How to add financial dimension to Dynamics AX Default cubes Blog bot DAX Blogs 0 13.01.2011 16:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 02:59.
