Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 30.05.2012, 14:04   #1
ist is offline
ist
Ax 2009 multiselect values in lookup
Hello,
Is there any way in ax 2009 to make a lookup with multiselect rows and selected values to be separated with semicolon each other in caller lookup control. This is possible in ax 2012 but for ax 2009 I didn't find any info.
Any solution would be welcome!
Regards,
ist.
Старый 30.05.2012, 14:44   #2
S.Kuskov is offline
S.Kuskov
3,440 / 1775 (66) ++++++++
Use the FormRun.closeSelect() method to determine the return value
Последний раз редактировалось S.Kuskov; 30.05.2012 в 15:10.
За это сообщение автора поблагодарили: ist (1).
Старый 31.05.2012, 01:32   #3
ist is offline
ist
Thank you very much!
Старый 06.06.2012, 14:49   #4
Vigotshvili is offline
Vigotshvili
What about multiselect values in lookup on EP AX 20009? Is it possible?
semanticax: Dynamics AX 2009 Installation - Application Blog bot DAX Blogs 0 22.12.2010 08:11
Часовой пояс GMT +3, время: 02:30.
