Старый 04.06.2012, 17:11   #1
25,644 / 848 (80) +++++++
How to get AOS name to attach to in Visual Studio 2010
Источник: http://alexvoy.blogspot.com/2012/06/...ach-to-in.html
When you are going to debug your AX application in Visual Studio 2010, it is not so easy to choose which AOS to attach to. There is no hint on the names of AOS services, if you have multiple instances installed on the same machine. The only way I have found is just to copy the application file path from this dialog and paste it into Notepad, for example, to see the whole name of AOS.
Let me know if you know a better way!
daxdilip: Tip - How to Retrieve AOS Instance name in Dynamics AX via X++ Code Blog bot DAX Blogs 0 24.11.2011 11:11
Dynamics CRM Tools: Visual Studio 2010 templates for Plugins and Custom workflow activities Blog bot Dynamics CRM: Blogs 0 15.04.2011 20:12
Запуск Visual Studio 2010 (онлайн-трансляция) slivka_83 Обучение 2 13.04.2010 20:16
emeadaxsupport: Visual Studio Dynamics AX report development how to associate X++ class with report dataSet Blog bot DAX Blogs 0 13.01.2010 23:08
Часовой пояс GMT +3, время: 11:28.
