#1 |
sashanazarov: Parm-methods generator script
Источник: http://sashanazarov.blogspot.com/201...or-script.html
============== It may be boring to manualy create parm-methods for each an every class member variable, although there is an editor script for that. By the way, there is a bug-o-feature in AX 2012 editor, which does not allow you to select anything but an EDT for the variable type. This is a script that auto-generates parm-methods for a class, based on its class declaration: <span style="font-size: x-small;">static void createParmMethod(Args _args) { #AOT ClassName className = classStr(MyClass); //
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
