Старый 31.08.2012, 23:11   #1
emeadaxsupport: AX 2012 - Proper configuration usage is critical when you have multiple Dynamics AX 2012 environments
Источник: http://blogs.msdn.com/b/axsupport/ar...ironments.aspx
Hi all,
Lately in support we have been getting lots of questions that tie back to configuration usage. This can manifest itself in many different ways:
  • Not finding an object to use as a report datasource in Visual Studio 2010 while the object shows up in the AOT.
  • Attempting to deploy a report and it is not found.
  • Objects deploying to the wrong location.
There are more, but you can see a pattern here. The root cause tends to be the configuration being used across the different environments. Recommendations really start with stating that the configuration file or registry based configuration be examined to make sure it is pointing to the correct AOS/database combination, and the WCF configuration information is correct. More information on this can be found at http://technet.microsoft.com/en-us/l.../aa569651.aspx .
Once this has been verified, make sure to examine what configuration is being used to open Visual Studio 2010. This process is discussed at http://msdn.microsoft.com/en-us/library/gg889291.aspx .
So, in summary, if you are seeing strange behavior where objects are not being found, deployments go to the wrong stop, or things like the Visual Studio 2012 Application Explorer doesn't seem to match what is being displayed in the Dynamics AX 2012 Development workspace, you may want to start looking at your configurations and which is being used in Visual Studio 2010.
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 09:42.
