#1 |
DynamicsAxSCM: AX2012 Purchasing with: Advanced warehouse management and quarantine management.
Источник: http://blogs.msdn.com/b/dynamicsaxsc...ne-orders.aspx
============== AX2012 Purchasing with: Advanced warehouse management and quarantine management. If it’s ever been an issue for you that no items in Contoso CEU are set up with both advanced warehouse management and quarantine management this information might be useful to you. Here you get a cheat sheet that you can use to set up Contoso CEU in order to handle an advanced warehouse procedure like the following in AX2012. Go to Inventory and warehouse management/Setup/Inventory breakdown/Warehouses
Close the form and go to Product information management/Released products and select item 1601 Navigate to the action pane tab Manage Inventory and click Warehouse items Save and close From the detailed item form open the item model group FRP_Pick. This way you enable quarantine management for the item arrival journal lines. You can also set this parameter for individual item arrival journal lines Now item 1601 is set up with advanced warehouse management and quarantine order, so try the procedure: Go to Procurement and sourcing/Purchase orders/All purchase orders
Go to Inventory and warehouse management/Periodic/Arrival overview
The pallet and the item are now recorded in the inbound location and a pallet transport to the quarantine warehouse is ordered. Go to Inventory and warehouse management/Common/Pallet transport
Close all forms. Go to Inventory and warehouse management/Periodic/Quarantine order The quarantine order is reported as finished and an item arrival journal is created. Open the item arrival journal that was created. Click Post A pallet transport to the warehouse is ordered. Close all forms. Go to Inventory and warehouse management/Common/Pallet transport
Now the flow is completed. Источник: http://blogs.msdn.com/b/dynamicsaxsc...ne-orders.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
