#1 |
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to translate parameters values
Источник: http://blogs.msdn.com/b/axsupport/ar...rs-values.aspx
============== Sometime ago I run into following problem.
![]() 3. I deployed report and created display menu item and opened the report - I specified * for account number parameter I printed report in EN-US language – looks fine: ![]() I printed report in NL-BE language – parameters are not translated: ![]() To solve the problem we need to do a little more of development:
![]() b. use the new created dataset to fill the value of the parameter Customer_CustAccountStatement ![]() c. modify the parameter expression from Value to Label ![]() Then this parameter will translated correctly. 2. For parameter which use NoYes enum we can use expression: =Microsoft.Dynamics.Framework.Reports.BuiltInMethods.GetEnumLabelFromValue("NoYes", IIF(Parameters!Customer_InclTax.Value.Equals("Yes"),1,0), parameters!AX_RenderingCulture.Value, parameters!AX_UserContext.Value) Источник: http://blogs.msdn.com/b/axsupport/ar...rs-values.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
