Старый 20.09.2012, 17:11   #1
axaptacorner: How to create Query in AX 2012 through X ++ code
Источник: http://axaptacorner.blogspot.com/201...2-through.html
With the following job we can create and execute the query :
Static void Querytest(Args _Args)
Query query;
QueryBuildDataSource queryBuildDataSource;
QueryBuildDataSource queryBuildDataSource1;
QueryBuildRange queryBuildRange;
QueryRun queryRun;
CustTable custTable;
DirPartyTable DirPartyTable;
query=new query(); //Initialize Query
queryBuildDataSource=query.addDataSource(tableNum(CustTable)); //Add Query
queryBuildDataSource.addSortField(fieldNum(custTable,AccountNum),SortOrder::Descending); //Add sorting
queryBuildRange=queryBuildDataSource.addRange(fieldNum(CustTable,AccountNum)); // Add Range
queryBuildRange.value(queryValue('11')+('*')); // Add Query Value
queryBuildRange=queryBuildDataSource.addRange(FieldNum(CustTable,AccountNum));
queryBuildRange.value(queryValue('22')+('*'));
//queryBuildDataSource1=queryBuildDataSource.addDataSource(tableNum(CustTrans)); //Add other Data Source for Joining
//queryBuildDataSource1.relations(true);// Enable Relation
// queryBuildDataSource1.joinMode(JoinMode::InnerJoin);//Define Join Mode
queryRun= new QueryRun(query); //Pass query to run it
while(queryRun.next())
custTable=queryRun.get(tableNum(CustTable));
print(strFmt("Customer Name, Account num and Currency are %1 , %2 and %3",DirPartyTable::findRec(CustTable.Party).Name,CustTable.AccountNum,CustTable.Currency));
pause;
Happy AX coding!!!!!
axaptacorner: How to read CSV files in AX 2012 through X++ code Blog bot DAX Blogs 0 20.09.2012 17:11
axaptacorner: How to create General Journal in AX 2012 by X++ code Blog bot DAX Blogs 0 10.09.2012 23:15
Часовой пояс GMT +3, время: 22:04.
