Старый 08.02.2013, 00:11   #1
25,644 / 848 (80) +++++++
crminthefield: More juicy details on Dynamics CRM 2011 Asynchronous Service’s maintenance jobs
Источник: http://blogs.msdn.com/b/crminthefiel...ance-jobs.aspx
You're likely aware that the Dynamics CRM 2011 Asynchronous Service regularly executes multiple internal maintenance jobs for each organization (database) and that these are scheduled initially at the time of organization creation on default frequencies (daily, monthly, etc.). Hopefully, you're also aware of the need to reschedule these jobs to execute during non-peak usage hours so as to minimize impact on system performance. If not, I urge you to review our previous blog post that discusses a tool created by one of our team members for this exact purpose, the CRM 2011 Maintenance Job Editor (http://crmjobeditor.codeplex.com).
Earlier we took an in-depth look at one of the more intriguing maintenance jobs in particular, the Deletion Service. But what about those other jobs? For those curious types like myself, here are the juicy details:
Maintenance Job
Operation Code
Purpose
Default Frequency
DeletionService
14
In CRM 4.0, this operation had a more prominent role in that it was responsible for all physical data deletion which occurred asynchronously, but that role has been greatly diminished in 2011 since all entity data is physically deleted immediately. It now performs periodic cleanup of artifacts that were previously associated to deleted entity records such as SubscriptionTracking and POA records.
Daily
IndexingManagement
15
Validates that system-managed indexes exist for all entities and recreates any missing indexes.
Daily
ReindexAll
30
Reorganizes/rebuilds fragmented indexes depending on the amount of fragmentation, and performs a DBCC SHRINKDATABASE command to release unused physical drive space for both database and transaction log files.  The latter works well for CRM Online organizations where drive space allocation is governed, but for on-premise environments we generally recommend postponing this job to essentially disable it (next run 1/1/2099) and opt for implementing your own index maintenance routine that does not shrink the physical files.
Daily
CleanupInactiveWorkflowAssemblies
31
Seeks custom workflow assemblies that are no longer referenced in workflow rules or in-process jobs. Those unreferenced assemblies are then deleted. Consider the scenario where you register version 2.0 of a custom workflow assembly.  You may update your rules to reference the new version, but some in-progress jobs may still be referencing version 1.0.  Once those jobs have completed, this maintenance job will clean up the version 1.0 assembly that is no longer referenced by rules/jobs.
Daily
AuditPartitionCreation
41
Alters the partitioning scheme for the auditbase table (SQL Enterprise only).
Monthly
CheckForLanguagePackUpdates
42
Detects upgrades to language (MUI) packs and schedules additional worker processes to perform provisioning.
Daily
(UR10+) RefreshRowCountSnapshots
46
Refreshes the Record Count snapshot statistics leveraged in UR10's enhanced query plans.
Daily
(UR10+) RefreReadSharingSnapshots
47
Refreshes the POA read snapshot statistics leveraged in UR10's enhanced query plans.
Daily
Remember, since the above jobs are technically internal operations, they are subject to change without notice. We'll do our best to keep this article updated on any changes we identify in future updates. If you'd like to see the Deployment SDK extended to provide API's for managing the above operations, please make your voice heard by signing up for Dynamics Suggestions on Microsoft Connect and vote for this feature hereAnd, while you're on Dynamics Suggestions take some time to vote on other feedback or create feedback of your own.
Austin Jones
Microsoft Premier Field Engineer
Microsoft Dynamics CRM Team Blog: Enabling Kerberos for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 20.09.2012 02:13
Microsoft Dynamics CRM Team Blog: The Microsoft Dynamics CRM Swiss Army Knife Blog bot Dynamics CRM: Blogs 1 19.04.2012 08:20
crminthefield: Dynamics CRM 2011 DeletionService Async Maintenance Operation Demystified Blog bot Dynamics CRM: Blogs 0 16.03.2012 00:11
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 18 Blog bot Dynamics CRM: Blogs 0 01.07.2011 02:12
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 06.05.2011 09:11
Часовой пояс GMT +3, время: 03:45.
