Старый 05.07.2013, 19:12   #1
emeadaxsupport: Understanding messages that appear in a RecID conflict project
Источник: http://blogs.msdn.com/b/axsupport/ar...t-project.aspx
Greetings all - every once in a while, when running a Best Practice Check or creating a set of Code Upgrade Projects, you may run across errors related to RecID and TableID conflicts, which really indicate failure to properly use the RefRecID and RefTableID EDTs. Here is a listing of the most common errors seen and some suggested resolutions:
Conflict Message - RecId relation missing This conflict occurs when a table contains a field that uses the RefRecId extended data type (or derived type) but no relation is defined for that field.
Resolution Tip -To resolve a RecId relation missing conflict, either define the missing relation or don’t use RefRecId as an extended data type on the field.
Conflict Message - TableId relation missing This conflict occurs when a table contains a field that uses the RefTableId extended data type (or derived type) but no relation is defined for that field.
Resolution Tip - To resolve a TableId relation missing conflict, either define the missing relation or don’t use RefTableId as an extended data type on the field.
Conflict Message - Field uses RecId This conflict occurs when a table field uses the RecId extended data type.
Resolution Tip - To resolve a field uses RecId conflict, you must use RefRecId or a derived extended data type and define the relation that actually uses this field.
Conflict Message - Field uses TableId This conflict occurs when a table field uses the TableId extended data type.
Resolution Tip - To resolve a field uses TableId conflict, you must use TableRecId or a derived extended data type.
Conflict Message - Type extends RecId This conflict occurs when you create a new extended data type that extends the RecId type.
Resolution Tip - To resolve a type extends RecId conflict, you have to change the extending type to RefRecId.
Conflict Message - Type extends TableId This type of conflict is similar to the type extends RecId conflict. It occurs when an extended data type extends the TableId type.
Resolution Tip - To resolve a type extends TableId conflict, you have to change the extending type to RefTableId.
emeadaxsupport: Timesheet workflows in Project management and accounting AX 2012 Blog bot DAX Blogs 0 21.06.2013 15:11
emeadaxsupport: Project Server Integration–the list of event handlers created by Dynamics AX synchronization Blog bot DAX Blogs 0 18.04.2011 23:11
emeadaxsupport: MS Project Integration resources with comma fail to export Blog bot DAX Blogs 0 12.05.2010 01:05
Часовой пояс GMT +3, время: 13:19.
