Старый 29.11.2013, 13:11   #1
emeadaxsupport: SEPA affected objects
Источник: http://blogs.msdn.com/b/axsupport/ar...d-objects.aspx
Here is a list of the objects affected by our SEPA update. The objects listed concerns each of our supported versions. AX 2009, AX 2012 & AX2012 R2 so you might have to scroll down a bit if you are on a later version. You can learn more about the latest status(2013) of SEPA here http://blogs.msdn.com/b/axsupport/ar...mber-2013.aspx
AX 2009
\Data Dictionary\Tables\AddressCountryRegion
\Data Dictionary\Tables\CompanyInfo
\Data Dictionary\Tables\CustBankAccount
\Data Dictionary\Tables\CustDirectDebitMandate
\Data Dictionary\Tables\CustDirectDebitMandateLog
\Data Dictionary\Tables\CustDirectDebitMandateLogRecord
\Data Dictionary\Tables\CustInvoiceJour
\Data Dictionary\Tables\CustInvoiceTable
\Data Dictionary\Tables\CustParameters
\Data Dictionary\Tables\CustPaymModeTable
\Data Dictionary\Tables\CustTable
\Data Dictionary\Tables\CustTrans
\Data Dictionary\Tables\CustTransOpen
\Data Dictionary\Tables\LedgerJournalTrans
\Data Dictionary\Tables\ProjInvoiceJour
\Data Dictionary\Tables\SalesTable
\Data Dictionary\Maps\AddressMap
\Data Dictionary\Maps\CustVendTrans
\Data Dictionary\Extended Data Types\BankDebitDirectId
\Data Dictionary\Extended Data Types\CUC_IT
\Data Dictionary\Extended Data Types\CustBankSubmissionDays
\Data Dictionary\Extended Data Types\CustDirectDebitMandateLogRecordValue
\Data Dictionary\Extended Data Types\CustDirectDebitMandateRecId
\Data Dictionary\Extended Data Types\CustMandateCancellationDate
\Data Dictionary\Extended Data Types\CustMandateExpectedUsageCount
\Data Dictionary\Extended Data Types\CustMandateId
\Data Dictionary\Extended Data Types\CustMandateMonthsToExpiration
\Data Dictionary\Extended Data Types\CustMandateSignatureDate
\Data Dictionary\Extended Data Types\CustMandateUsageCount
\Data Dictionary\Extended Data Types\CustPaymIsSEPA
\Data Dictionary\Extended Data Types\CustPrenotificationDays
\Data Dictionary\Extended Data Types\SEPADirectDebitIssuerType
\Data Dictionary\Base Enums\BankIBSPaymType
\Data Dictionary\Base Enums\CustDirectDebitMandateLogRecordKey
\Data Dictionary\Base Enums\CustDirectDebitMandateState
\Data Dictionary\Base Enums\CustMandatePaymentType
\Data Dictionary\Base Enums\CustMandateScheme
\Data Dictionary\Base Enums\CustMandateStatus
\Data Dictionary\Base Enums\RemmitanceInfo
\Data Dictionary\Base Enums\SEPADirectDebitIssuer
\Data Dictionary\Base Enums\SEPAMessageVariantDE
\Classes\AddressSelectForm
\Classes\AddressSelectForm_CustDirectDebitMandate
\Classes\AxCompanyInfo
\Classes\AxCustInvoiceJour
\Classes\AxCustInvoiceTable
\Classes\AxCustPaymModeTable
\Classes\AxCustTable
\Classes\AxCustTrans
\Classes\AxProjInvoiceJour
\Classes\AxSalesTable
\Classes\BankPaymCancel
\Classes\CustCollectEInvoice_CustTable_NO
\Classes\CustCustomer_CustTable
\Classes\CustDirectDebitMandateLogHelper
\Classes\CustFreeTextInvoice_CustInvoiceTable
\Classes\CustOutPaym
\Classes\CustOutPaym_SEPA
\Classes\CustOutPaym_SEPA_BE
\Classes\CustOutPaym_SEPA_DE
\Classes\CustOutPaym_SEPA_ES
\Classes\CustOutPaym_SEPA_FR
\Classes\CustOutPaym_SEPA_IT
\Classes\CustOutPaym_SEPA_NL
\Classes\CustOutPaymRecord_SEPA
\Classes\CustOutPaymRecord_SEPA_BE
\Classes\CustOutPaymRecord_SEPA_DE
\Classes\CustOutPaymRecord_SEPA_ES
\Classes\CustOutPaymRecord_SEPA_FR
\Classes\CustOutPaymRecord_SEPA_IT
\Classes\CustOutPaymRecord_SEPA_NL
\Classes\CustReversePosting
\Classes\CustVendOutPaym
\Classes\CustVendOutPaymRecord
\Classes\CustVendPaymProposalTransferToJournal
\Classes\CustVoucher
\Classes\LedgerJournalTransUpdateCust
\Classes\NumberSeqReference_Customer
\Classes\ProdProjEInvoice_CustPaymModeTable
\Classes\ProdProjEInvoice_CustTable
\Classes\ProdProjEInvoice_CustTrans
\Classes\ProdProjEInvoice_ProjInvoiceJour
\Classes\ReturnReturnOrderIn_SalesTable
\Classes\ReturnReturnOrderOut_SalesTable
\Classes\SalesSalesEInvoice_CustInvoiceJour
\Classes\SalesSalesEInvoice_CustPaymModeTable
\Classes\SalesSalesEInvoice_CustTable
\Classes\SalesSalesEInvoice_CustTrans
\Classes\SalesSalesInvoice_CustInvoiceJour
\Classes\SalesSalesOrder_SalesTable
\Classes\VendOutPaym
\Classes\VendOutPaym_SEPA
\Classes\VendOutPaym_SEPA_AT
\Classes\VendOutPaym_SEPA_BE
\Classes\VendOutPaym_SEPA_DE
\Classes\VendOutPaym_SEPA_DEPrintable
\Classes\VendOutPaym_SEPA_ES
\Classes\VendOutPaym_SEPA_FI
\Classes\VendOutPaym_SEPA_FR
\Classes\VendOutPaym_SEPA_IT
\Classes\VendOutPaym_SEPA_NL
\Classes\VendOutPaym_SEPA03
\Classes\VendOutPaym_SEPA03_AT
\Classes\VendOutPaym_SEPA03_BE
\Classes\VendOutPaym_SEPA03_DE
\Classes\VendOutPaym_SEPA03_ES
\Classes\VendOutPaym_SEPA03_FI
\Classes\VendOutPaym_SEPA03_FR
\Classes\VendOutPaym_SEPA03_IT
\Classes\VendOutPaym_SEPA03_NL
\Classes\VendOutPaymRecord_ISO20022_Gen_BE
\Classes\VendOutPaymRecord_SEPA
\Classes\VendOutPaymRecord_SEPA_AT
\Classes\VendOutPaymRecord_SEPA_BE
\Classes\VendOutPaymRecord_SEPA_DE
\Classes\VendOutPaymRecord_SEPA_ES
\Classes\VendOutPaymRecord_SEPA_FI
\Classes\VendOutPaymRecord_SEPA_FR
\Classes\VendOutPaymRecord_SEPA_IT
\Classes\VendOutPaymRecord_SEPA_NL
\Classes\VendOutPaymRecord_SEPA03
\Classes\VendOutPaymRecord_SEPA03_AT
\Classes\VendOutPaymRecord_SEPA03_BE
\Classes\VendOutPaymRecord_SEPA03_DE
\Classes\VendOutPaymRecord_SEPA03_ES
\Classes\VendOutPaymRecord_SEPA03_FI
\Classes\VendOutPaymRecord_SEPA03_FR
\Classes\VendOutPaymRecord_SEPA03_IT
\Classes\VendOutPaymRecord_SEPA03_NL
\Forms\CompanyInfo
\Forms\CustDirectDebitMandate
\Forms\CustDirectDebitMandateLookup
\Forms\CustFreeInvoice
\Forms\CustOpenTrans
\Forms\CustOpenTransReverse
\Forms\CustParameters
\Forms\CustPaymEntry
\Forms\CustPaymMode
\Forms\CustTable
\Forms\CustTrans
\Forms\CustTransOpen
\Forms\LedgerJournalTransCustPaym
\Forms\SalesTable
\Reports\CustDirectDebitMandate
\Reports\CustDirectDebitMandateInvoice
\Reports\FreeTextInvoice
\Reports\ProjInvoice
\Reports\SalesInvoice
\Reports\VendOutAttendingNote_SEPA_DE
\Reports\VendOutCoveringLetter_SEPA_DE
\Reports\VendOutPaymControl
\Menu Items\Display\CustDirectDebitMandate
\Menu Items\Output\CustDirectDebitMandateInvoiceReport
\Menu Items\Output\CustDirectDebitMandateReport
\Menu Items\Output\VendOutAttendingNote_SEPA_DE
\Menu Items\Output\VendOutCoveringLetter_SEPA_DE
AX 2012
\Data Dictionary\Tables\CustDirectDebitMandateInvoiceHeaderTmp
\Data Dictionary\Tables\CustDirectDebitMandateInvoiceTmp
\Data Dictionary\Tables\CustDirectDebitMandateTmp
\Data Dictionary\Tables\CustVendOutTmp
\Data Dictionary\Tables\DocuRef
\Data Dictionary\Tables\FreeTextInvoiceTmp
\Data Dictionary\Tables\ProjInvoiceTmp
\Data Dictionary\Tables\SalesInvoiceDetailTmp
\Data Dictionary\Tables\SalesInvoiceHeaderFooterTmp
\Data Dictionary\Views\CustDirectDebitMandateLogView
\Macros\AifPaymentFormats
\Macros\AxdCustPaymentsDCT
\Classes\AifMessage
\Classes\AifMessageParts
\Classes\AxdExportCustVendPayment
\Classes\CustDirectDebitMandateContract
\Classes\CustDirectDebitMandateController
\Classes\CustDirectDebitMandateDP
\Classes\CustDirectDebitMandateInvoiceController
\Classes\CustDirectDebitMandateInvoiceDP
\Classes\CustECollectLetter_CustTable_NO
\Classes\CustPayments_CustDirectDebitMandate
\Classes\CustPayments_CustTable
\Classes\CustPayments_CustTrans
\Classes\CustPayments_Log
\Classes\CustPayments_LogRecord
\Classes\CustPayments_LogView
\Classes\CustVendPaymAifSetup
\Classes\FreeTextInvoiceDP
\Classes\NumberSeqModuleCustomer
\Classes\ProjInvoiceDP
\Classes\ProjInvoiceJournalPost
\Classes\SalesInvoiceDP
\Classes\VendOutPaymControlAIF
\Forms\CustPaymMode
\Forms\CustTable
\Forms\CustTrans
\Forms\OMLegalEntity
\Forms\SalesCopying
\Forms\SalesTable
\SSRS Reports\Reports\CustDirectDebitMandate
\SSRS Reports\Reports\CustDirectDebitMandateInvoice
\SSRS Reports\Reports\FreeTextInvoice
\SSRS Reports\Reports\ProjInvoice
\SSRS Reports\Reports\SalesInvoice
\SSRS Reports\Reports\VendOutPaymControl
\Visual Studio Projects\Dynamics AX Model Projects\CustDirectDebitMandateInvoiceReport
\Visual Studio Projects\Dynamics AX Model Projects\CustDirectDebitMandateReport
\Queries\CustPayments
\Menu Items\Display\CustDirectDebitMandateEdit
\Menu Items\Display\CustDirectDebitMandateNew
\Menu Items\Display\CustDirectDebitMandateView
\Security\Privileges\CustTableMaintain
\Resources\CustPayments_SEPADirectDebit_02_xslt
\Resources\VendPayments_SEPACreditTransfer_03_xsl
\Resources\VendPayments_SEPACreditTransfer_xslt
\Resources\VendPayments_SEPATruncateTags_xslt
\Resources\VendPayments_SEPATruncateTagsAndBOM_xslt
AX 2012 R2
\Data Dictionary\Tables\FreeTextInvoiceHeaderFooterTmp
\Data Dictionary\Tables\FreeTextInvoiceLocalizationTmp
\Data Dictionary\Tables\ProjInvoiceLocalizationTmp
\Data Dictionary\Tables\PSAContractLineInvoiceTmp
\Data Dictionary\Tables\PSACustRetentionReleaseInvoiceTmp
\Data Dictionary\Tables\PSAManageInvoiceBRTmp
\Data Dictionary\Tables\PSAManageInvoiceTmp
\Data Dictionary\Tables\PSAProjInvoiceHeaderTmp
\Data Dictionary\Tables\SalesInvoiceLocalizationTmp
\Data Dictionary\Tables\SalesInvoiceTmp
\Classes\PSAContractLineInvoiceDP
\Classes\PSACustRetentionReleaseInvoiceDP
\Classes\PSAManageInvoiceBRDP
\Classes\PSAManageInvoiceDP
\Classes\PSAProjInvoiceDP
\Classes\SalesInvoiceDPBase
\Forms\CustPaymMode
\Forms\CustTable
\Forms\CustTrans
\Forms\SalesCopying
\Forms\SalesTable
\SSRS Reports\Reports\PSAContractLineInvoice
\SSRS Reports\Reports\PSACustRetentionReleaseInvoice
\SSRS Reports\Reports\PSAManageInvoice
\SSRS Reports\Reports\PSAManageInvoiceBR
\SSRS Reports\Reports\PSAProjInvoice
emeadaxsupport: Invitation to EMEA webinar - How to setup SEPA in Dynamics AX 2012 and an overview of published hotfixes Blog bot DAX Blogs 0 17.10.2013 17:11
emeadaxsupport: SEPA - One page stop with current information. Blog bot DAX Blogs 0 22.02.2013 13:11
emeadaxsupport: Turn off Keep Update objects in AX 2012 for new installations Blog bot DAX Blogs 0 19.04.2012 21:11
emeadaxsupport: Identifying damaged Table objects in the AOT MetaData Blog bot DAX Blogs 0 16.03.2010 21:05
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
Часовой пояс GMT +3, время: 14:36.
