#1 |
emeadaxsupport: AX Retail: Enabling reliable session support in POS – RealTimeServices in AX 2012 R2
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
============== Description: We have received some feedback from customers that inconsistence occurs when the network connect fails during a RealTimeService operation from the POS. To ensure that POS calls to RealTimeService is working reliable, we can enable the reliable session in the config files. After enabling this feature, the communication will ensure consistency in the calls. NB: Enabling this feature might slightly decrease the performance. Solution: When you want to edit the Web.Config or POS.Exe.Config file it is a very good practice to use the SvcConfigEditor.exe, which comes with the Microsoft SDK. With this tool it is very easy to see the possible values in the different options and it provides you a good overview what is running as a service and what is running on the client. ![]() To get the reliable session to work we have to change certain values.
Example files: Content might have to be adjusted. POS.EXE.CONFIG file WEB.CONFIG FILE NB. The next release of AX (Dynamics AX 2012 R3) has reliable session enabled by default. Author: Kim Truelsen Date: 11/2-2014 Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
