Старый 01.09.2014, 14:11   #1
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 7
Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-7.aspx
This is page 7 of 8 of the general performance analysis scripts online for the Performance Analyser 1.20 tool. See page 1 for the introduction. Use the links in the table below to navigate between pages.
- General analysisAnalyse SQL ConfigurationPage 1Analyse SQL IndexesPage 2Analyse SQL QueriesPage 3Analyse BlockingPage 4Baseline - benchmark queriesPage 5- AX SpecificAnalyse AX ConfigurationPage 6Analyse AX IndexesPage 7Analyse AX QueriesPage 8Analyse AX Indexes
INDEXES_IN_DB_NOT_IN_AOT
INDEXES_WITH_RECVERSION
-- INDEXES_IN_DB_NOT_IN_AOT
-- Find INDEXES that are not defined in the AOT
SELECT *
FROM INDEX_STATS_CURR_VW I
WHERE INDEX_DESCRIPTION 'HEAP' AND INDEX_DESCRIPTION NOT LIKE '%FILTERED%'
AND NOT EXISTS (SELECT *
FROM AX_INDEX_DETAIL_CURR_VW A
WHERE A.DATABASE_NAME = I.DATABASE_NAME
AND A.TABLE_NAME = I.TABLE_NAME
AND A.INDEX_NAME = I.INDEX_NAME)
ORDER BY TABLE_NAME,
INDEX_NAME
-- INDEXES_WITH_RECVERSION
-- Find INDEXES that have RECVERSION in the Key or Included list
-- RECVERSION should NOT be apart of AX Indexes do to the
-- frequency of updates
SELECT *
WHERE INDEX_KEYS LIKE '%RECVERSION%'
OR INCLUDED_COLUMNS LIKE '%RECVERSION%'
INDEX_NAME
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 3 03.08.2011 09:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 20:31.
