Старый 17.12.2014, 01:12   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Project Management and Service Industries Hotfixes Released in December 2014 (Part 1)
Источник: http://blogs.msdn.com/b/axsupport/ar...14-part-1.aspx
In this blog series I will be posting the hotfixes released for the Project Management and Accounting, as well as the Service Industries modules for Dynamics AX 2012 R2 and Dynamics AX 2012 R3 twice each month. I would like to raise visibility for customers and partners to see what's been updated and changed, as there's many fixes that change and improve existing functionality. It will also give customers and partners a chance to be proactive if any of these appear to be something you might encounter in the future.
I will break these hotfixes down between the two releases. Keep in mind that a hotfix is first released on the build that the issue or design change is reported for. If you see a hotfix that exists in a different release, search for the fix in Lifecycle Services to see if it exists for your build. If the hotfix does not exist in Lifecyle Services for your version, there's a strong chance that it is in the works of being developed for your build of AX. In that scenario, the recommendation would be to submit a new support request so we can track the need for the hotfix.
If you see a hotfix that you would like to download and test, please log into Microsoft Dynamics Lifecycle Services (https://lcs.dynamics.com/) to review code changes, search for related issues, and download the hotfix for testing. If you are unfamiliar with Lifecycle Services, review the following blog for instructions on using Lifecycle Services to download a hotfix:
http://blogs.msdn.com/b/axsupport/ar...-hotfixes.aspx
If you have any questions about these fixes that cannot be answered by Lifecycle Services, please activate a new support request so our Project Engineers can assist you.
Watch for these posts twice each month, and I look forward to any suggestions and feedback!
Tyler Lewin
Senior Support Engineer
Microsoft Dynamics AX
Dynamics AX 2012 R2
KB 3025429 - Allows timesheets with multiple funding sources to be posted, where before we would get an error "Cannot create a record in Hours (ProjEmplTrans). The record already exists."
KB 3024345 - This hotfix will allow a sales order that's marked on a project purchase order to remain marked when the quantity is changed.
KB 3018464 - If you override the exchange rate for an intercompany expense report in EP, this fix will ensure the new rate is used by the destination company.
KB 3019592 - After this hotfix, the copy functionality in the project wizard will now copy the schedule dates as well.
KB 3023357 - If an expense entry in EP is including tax, this hotfix will correct the tax ledger postings and calculation (net vs. gross).
KB 3023298 - When rate changes occur before payment, the payment amount will now match employee expense report amount when vendor invoice is posted in a foreign currency.
KB 3024736 - This hotfix will make sure that the actual sales tax amount is unchanged when changing the project category on project journals.
KB 3020830 - If a user clicks "Submit" more than once, this hotfix make sure that only one workflow instance is created.
KB 3022290 - This will keep the correct project sales price when a user adjusts the sales tax amount and then enters a project category and makes sure the tax amount is not recalculated.
KB 3020829 - With this fix, project invoices will now respect print management settings.
KB 3021985 - This will ensure that on-account transactions will use the correct funding source (for example if allocation rules post a different funding source to a specific activity).
Dynamics AX 2012 R3
KB 3017097 - This will make AX consider the project date while adjusting expense transactions in a previous closed period when functionality to post to closed periods is enabled.
KB 3017580 - Resolves an issue where itemization gets completed even if there is an amount remaining on credit card related expense lines.
KB 3024334 - If we post a timesheet for a terminated employee, this will allow those transactions posted with the company code, where before it was blank.
KB 3024396 - Resolves the error "Function AccDistProcessorProjectExtension.createForProjectRevenueLine has been incorrectly called." when submitting negative timesheets with a WIP Sales Project group.
KB 2963242 - Use this hotfix to update the services required for the new versions of companion apps.
KB 3018871 - This hotfix will update the policy violations for expense reports in EP when users click the "Save and close" button.
KB 2994338 - This will ensure correct funding course reservations on a project contract when creating a change order or a variance on a vendor invoice.
Previous hotfix blog: http://blogs.msdn.com/b/axsupport/ar...mber-2014.aspx
emeadaxsupport: Project Management and Service Industries Hotfixes Released in November 2014 Blog bot DAX Blogs 0 19.11.2014 02:14
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
emeadaxsupport: AX for Retail 2012 R2: Troubleshooting the Real-time Service Blog bot DAX Blogs 0 31.12.2012 11:13
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
Microsoft Dynamics CRM Team Blog: Fast, Efficient Growth for Project Management Solution - Case Studies Blog bot Dynamics CRM: Blogs 0 01.02.2012 03:18
Часовой пояс GMT +3, время: 22:14.
