Старый 23.03.2015, 22:12   #1
25,644 / 848 (80) +++++++
Dynamics AX Sustained Engineering: Announcing an update to enable the use of SQL Server 2014 with the AX 2012 R2 CU7 version of the Data Import/Export Framework (DIXF)
Источник: http://blogs.technet.com/b/dynamicsa...work-dixf.aspx
We are pleased to announce the availability of KB 3018235, which enables the AX 2012 R2 cumulative update 7 version of DIXF to run with Integration Services from SQL Server 2014.
This update is also available in the recently released AX 2012 R2 CU8.
For information about installing and using the hotfix, see:
You can also refer to the Microsoft Dynamics AX 2012 System Requirements for more information.
ax2012, sql server 2014
Dynamics AX Sustained Engineering: Announcing Support for SQL Server, SharePoint, and Office 2013 Service Packs as well as Visual Studio Team Foundation Server and Visual Studio Online Blog bot DAX Blogs 0 09.10.2014 23:11
Dynamics AX Sustained Engineering: Announcing Support for Windows Server 2012 R2 and SharePoint 2013 SP1 Blog bot DAX Blogs 0 18.07.2014 02:14
mfp: AX 2012 R2 CU7 has been released! Blog bot DAX Blogs 14 26.11.2013 12:12
Dynamics AX Sustained Engineering: Announcing Cumulative Update 4 for Microsoft Dynamics AX 2012 & Microsoft Dynamics AX 2012 Feature Pack 1 Blog bot DAX Blogs 0 05.12.2012 01:11
Часовой пояс GMT +3, время: 07:07.
