Старый 04.03.2016, 23:11   #1
25,644 / 848 (80) +++++++
organicax: WMS Allow pick location override
Источник: http://organicax.com/2016/03/03/wms-...tion-override/
In a previous post we had a look at the allow put location override parameter. There is a companion parameter to this if you want to allow the use to be able to change the pick location. This can be handy if the physical stock doesn’t match the system suggested location. The system suggested location will come from the location directives.
The parameter is called allow pick location override and can be found on the warehouse worker setup.
Here is a quick walk through in AX2012 R3 CU9
AX Build 7.0.1265.3015
Cheers
Lachlan
Filed under: Warehouse management
organicax: WMS Consolidate shipments – manual Blog bot DAX Blogs 0 04.03.2016 23:11
organicax: WMS Release to warehouse form Blog bot DAX Blogs 0 04.03.2016 23:11
organicax: WMS Automatically create load at sales order entry Blog bot DAX Blogs 0 04.03.2016 23:11
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
DynamicsAxSCM: Migration of Microsoft Dynamics AX WMS to new R3 warehouse and transportation functionality Blog bot DAX Blogs 0 17.08.2015 20:19
Часовой пояс GMT +3, время: 23:27.
