#1 |
Hi,
Получаем ошибку всякий раз, когда пытаемся создать Calculated member например - Unable to create the calculated member. Formula error - syntax error - token isn't valid: "Select ^{^([Time].[1997]),([Time].[1998])}ON COLUMNS From HR Where ([Measures].[Count])" thx Ol. |
#2 |
Честно говоря, не пойму, откуда вы это сообщение получаете. Сам по себе запрос рабочий. И где тут calculated member ?
-ТСЯ или -ТЬСЯ ? |
#3 |
You are right,
in query pane it works fine. we are trying to do use select statement in the calculated member pane and it is not working. make sence. thank you. O. |
