Старый 31.07.2017, 18:12   #1
25,644 / 848 (80) +++++++
stoneridgesoftware: How to Install Red Maple Web Service for TLS2
Источник: https://stoneridgesoftware.com/how-t...vice-for-tls2/
Here is the documentation provided by Red Maple on how to install the Red Maple web service that is compatible with TLS 2.0
2009:
Please make sure the .NET 4.6 is installed on any server running AX or the web service provided.
  1. The patch includes two things:
  • A web service that was specially written for this purpose. The web service will need to be installed on a server that has IIS and the AX 2009 Business Connector.
  • An XPO. The XPO should have the classes associated with your processor. Please do not import the XPO wholesale. Please “merge” the code to make sure that if you version does not line up with the version we have used, additional errors will not occur. Remember that AX 2009 was released almost 8 years ago, a lot has happened to both AX and our product in that time.
  1. You should import the XPO with #1 in mind.
I am providing the detailed steps on how to setup this web service on an IIS server.  I have an all in one TEST server that has the IIS role and AX Business Connector installed. I then downloaded .NET 4.6.2 and installed it on this server.
If you have a multiple server environment you would need .NET 4.6.x installed on all the servers where the AX component is installed.
In the extracted folder from Red Maple, you will see a folder called RMTLS and containing the following in it –
Copy the RMTLS folder to Inetpub\RMTLS –
In IIS create a new website on port 81 pointing to the above folder – (port 80 was being used by AIFWebservices on this TEST server).
Right click on the RMTLS site> add an application. Called it RMTLS and enter the same physical path –
This is what the application pool looks like –
Edit the Advanced settings of the RMTLS application pool and set Enable 32 bit applications = True
Browse to the RedMaple.asmx page – and you should see this.
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Freddys: Multiple Service Tiers Blog bot Dynamics CRM: Blogs 0 30.10.2008 01:59
wiki.dynamicsbook: Changes Made in Navision Attain 3.60 Blog bot Dynamics CRM: Blogs 0 02.09.2008 13:23
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 03:55.
