Старый 16.11.2017, 20:11   #1
25,644 / 848 (80) +++++++
crmtipoftheday: Tip #1024: Make an entity regarding available from Outlook App
Источник: https://crmtipoftheday.com/1024/make...m-outlook-app/
If you use the Dynamics 365 App for Outlook (the new Outlook interface), when you set regarding, you may notice that not all of your entities are available. Yet there is no “Outlook” checkbox on the entity. How do determine which entities are available to be selected as regarding objects for email from the D365 Outlook app?
The entities must meet the following conditions:
  1. Be activity enabled (check the activity checkbox on the entity configuration)
  2. Be mobile enabled. Outlook App and CRM Mobile App share the same interface, and if the entity is not mobile enabled, you will not be able to select it for the regarding record in the Outlook app.
This also means that the small number of system entities that cannot be mobile enabled (mainly goals, marketing, and legacy service entities) cannot have related activities tracked via the D365 Outlook App.
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
Microsoft Dynamics CRM Team Blog: The new light-weight CRM App for Outlook Blog bot Dynamics CRM: Blogs 0 11.12.2015 04:14
Microsoft Dynamics CRM Team Blog: Track incoming email from anywhere with the new CRM App for Outlook Blog bot Dynamics CRM: Blogs 0 16.07.2015 00:12
wiki.dynamicsbook: Changes Made in Navision Attain 3.60 Blog bot Dynamics CRM: Blogs 0 02.09.2008 13:23
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 09:17.
