Старый 08.04.2018, 03:03   #1
25,644 / 848 (80) +++++++
crmtipoftheday: Tip #1103: Chart styling cheat sheet
Источник: https://crmtipoftheday.com/1103/char...g-cheat-sheet/
This post concludes chart week on CRM Tip of the Day. Thanks to Ulrik for these great tips.
It isn’t always obvious where to go in the chart XML to make changes to certain areas. We’ve created this handy cheat sheet so you can see where to go to change what in the chart.
Series
Besides the chart type for the series, you can set
  • Color of the series
  • Custom text for the legend
  • Visibility in legend
  • Label and formatting of each data point
  • Borders on the bars/columns
Series CustomProperties
Special properties specific to the chart type chose for the series.
  • Label positioning (i.e inside/outside/left/right/etc.)
  • Width of bars/columns
  • Drawing styles (make bars look like wedges or cylinders)
  • For pie/donuts and funnel charts there numerous custom properties
ChartArea
Background colors and borders
Axis
The axis has the most properties. Here are some of the most commonly used.
  • Custom Axis Title, font size and alignment
  • Max and Min values for the axis
  • Line of axis width, color, and style
  • Interval between values on axis
  • Crossing if you need a break different than zero (useful for survey results)
Axis LebelStyle
Value formatting for the axis
Annotations
Notes and comments to place on the chart in a specific place.
crmtipoftheday: Tip #1101: Add a scale break to charts Blog bot Dynamics CRM: Blogs 0 07.04.2018 04:03
crmtipoftheday: Tip #1099: Add Annotations to Charts Blog bot Dynamics CRM: Blogs 0 06.04.2018 06:15
crmtipoftheday: Tip #1097: Change chart labels on currency values to show in Millions or Thousands Blog bot Dynamics CRM: Blogs 0 04.04.2018 08:11
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 08:22.
